ONTAP Hardware
E-SERIES SIMULATOR ISCSI HOST PORT IS DISCONNECTED
oscaraock
Hi Guys,
Recentlly Ive installed the E-Series Simultator 11.40 but Im trying with the different arrays but all arrays shows the ISCSI Host Ports "Disconnected" and it not able to test LUNs.
May this is a mine error or is necessary adjust something (I've tried with Win10 and Win2012, uncompressed the files over C:
2 REPLIES 2
AlexDawson
Hi there,
This isn't my specialty, but have you checked you have ping connectivity between your hosts and the simulator? That would be the first thing to check.
oscaraock
Hi Alex,
The ping dont answer, the iscsi interfaces of the simulator are all down, the only interface up is the management.
In a real machine with the interfaces connected the status is up and is posible map iscsi volumes but with the simulator the funcionality is limted by it
