ONTAP Hardware
EOL FAS 9000
ramircar
Hi Team,
I´m searching information about End Of Life to FAS9000 & MetroCluster. Do U know any  link or Document to reference?
Thanks in Advanced
1 ACCEPTED SOLUTION
akiendl
End of support dates can usually be found here: https://mysupport.netapp.com/info/eoa/index.html?access=a
The FAS9000 has no EOS date posted as it is not yet End of Availbility. So you should have plenty of time.
ak.
1 REPLY 1
akiendl
ak.
