ONTAP Hardware
FAS 2040 IP trouble
CQUILA_COZANO
Hi,
This is my first post here in NetApp, I have a little bit trouble now, I was configuring a FAS2040 (two controllers - 4eth per controller) so I need to connect those controller in redundancy with three diferents Linux Server but, I need only one ip address like a virtual address in the both controller. I attch how i like to have the connection
I hope guy's  could be help me,
Cristian Quila,
Chile
[URL=http://imageshack.us/photo/my-images/688/fisoco.png/][IMG]http://img688.imageshack.us/img688/9967/fisoco.png[/IMG][/URL]
3 REPLIES 3
hadrienc
Hello Christian,
If you have ethernet swithces that support LACP, we would recommand that.
1.)What you can do is use on FAS1 ethernet 1 and 2 with LACP over one switch (LACP1) and ethernet 3 and 4 with LACP (LCAP2). (same on FAS2)
2.)Then you create a single mode vif with LACP1 and 2 (active/passif)
You will have then 2gbps redundant link going to 2 different switches.
Hope that can help.
If you use Cisco switches...LACP is the channel-group command...
Regards,
Hadrien
CQUILA_COZANO
Thx Hadrien for u answer,
So, I can have the two controller with the same IP address?? like a virtual IP address?, because I need to the Linux Servers see only one IP address
The switches are Cisco 2970 and I use LACP for the boundels
Best Regards
Topology https://dl-web.dropbox.com/get/Public/Topology.pdf?w=5115de1b
hadrienc
Hey,
No you'll have 2 ips, one for each controller.
Check this documentation:
http://now.netapp.com/NOW/knowledge/docs/ontap/rel802/html/ontap/nag/frameset.html
You ll find everything about network configuration.
Hope this help.
Regards,
Hadrien
