ONTAP Hardware
FAS 2040 shelf
joergjuh
Can anyone tell me where I can find a list with supported shelves drives for the FAS2040? I've been looking but have had no luck so far. Any help would be appreciated.
3 REPLIES 3
aborzenkov
You can find authoritative compatibility information at https://hwu.netapp.com/
Sahana
Hi,
Refer the attached file generated from hardware universe.
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
liuh
hi
Please check the attachment. I hope it will be helpful to you
