ONTAP Hardware
FAS 2520 Maximum usable space with one big aggregate
atlasship
Hi awesome community members,
In reference to my previous post, I have really awesome respond and I re-upgraded my *NEW* FAS2520 from 7-mode back to 9.2P2 cluster mode.
However, when I tried to create a new aggregate on the oncommand portal, it seems that 6 disks was assgined to node1 and node2, so I remembered I had to convert it to active/passive setup, and so I followed this article
So one last stupid question from me. What is the number_of_partitions I should be using? (reason I'm not sure is the articles showed 13 entries from its example, but mine only has 12 entries on the paritions/disks)
or is there a installation setup guide I could follow? I have not been able to find one. this is a FAS2520 with 12 x 4TB spec.
attached is current aggregate info.
Thank you so much!
- Atlas
1 ACCEPTED SOLUTION
AlexDawson
Hi there,
These would be the commands to run:
set advanced
storage disk assign -force -data true -owner profx-01 -disk 1.0.0
storage disk assign -force -data true -owner profx-01 -disk 1.0.2
storage disk assign -force -data true -owner profx-01 -disk 1.0.4
storage disk assign -force -data true -owner profx-01 -disk 1.0.6
storage disk assign -force -data true -owner profx-01 -disk 1.0.8
storage disk assign -force -data true -owner profx-01 -disk 1.0.10
storage aggregate rename -aggregate aggr0 -newname N1_aggr0
storage aggregate rename -aggregate aggr0_profx_02_0 -newname N2_aggr0
storage aggregate create N1_aggr1sata4TB -diskcount 11 -node profx-01
This will leave one 4TB partition spare - if you don't want to do that, change diskcount to 12. The exact choice comes down to how quickly you can be notified of failed disks, swap disks, etc.
1 REPLY 1
AlexDawson
Hi there,
set advanced
