ONTAP Hardware
FAS 2520 switchless
ANTONIO_SIMULA
Hi All, i need to install a new FAS2520 C-dot 8.3.2, in our Customer.
The client's network infrastructure is at 1gbits, so i was thinking of configuring the cluster interfaces of each node, in the switchless mode .
The Fas2520 support this type of configuration ?
The Cluster interfaces are e0d and e0f , for each node ?
We need to use a crossover cable or straight-trough cable ?
The command for switchless mode are this :
set -privileges advanced
network options switch switchless-cluster modify -enable true
set -privileges admin
Are the commands correct?
Thank you all
Antonio
1 ACCEPTED SOLUTION
NAYABSK
Hi Antonio,
Thank you for contacting NetApp community, The complete information with respect to FAS 25xx installation can found in the VIDEO below.
FAS25XX Installation
FAS2520 Setup Instructions
Yes It Supports Switchless Configuration
Yes
The command for switchless mode are:
1. Enter the following command to enable cluster HA:
cluster ha modify -configured true
If storage failover is not already enabled, you will be prompted to confirm enabling of both storage failover and auto-giveback.
If you have a two-node switchless cluster, enter the following commands to verify that the switchless-cluster option is set:
Enter the following command to change to the advanced-privilege level:
set -privilege advanced
Confirm when prompted to continue into advanced mode. The advanced mode prompt appears (*>).
Enter the following command:
network options switchless-cluster show
If the output shows that the value is false, you must issue the following command:
network options switchless-cluster modify true
Enter the following command to return to the admin privilege level:
set -privilege admin
Thanks,
Nayab
2 REPLIES 2
NAYABSK
Hi Antonio,
Yes
Thanks,
Nayab
ANTONIO_SIMULA
Hi Nayab, thanks for your rapids answers .
Regards
Antonio
