ONTAP Hardware
FAS 8020 to FAS8300
alef_brngal
Hi guys,
our customer wants to upgrade the old systems to the new one by upgrading the controllers. My question is, if is it possible and how to order, maybe an upgrade kit. thanks
FAS2554  to FAS2720
FAS2554 to shelf with IOM12
FAS8020 to FAS8300
FAS8040 to FAS8300
DS2246  and DS4246 to IOM12
2 REPLIES 2
GidonMarcus
Hi.
NetApp is heavily relying on partners to do sales and maintenance (although also have its own sales teams) I think the golden path is for you to either become a NetApp partner or contact one (perhaps the one the customer worked with before).
By having the insights of a partner you can see different offering for different controllers and chose from.
https://www.netapp.com/partners/
https://partner-connect.netapp.com/us/partner-directory
Gidi Marcus (Linkedin) - Storage and Microsoft technologies consultant - Hydro IT LTD - UK
junwang
Hi, alef_brngal ,
The ONTAP system firmware of the device can be upgraded to other versions, but the model cannot be directly upgraded. The internal configuration parameters of each model of device are different. If you have any requirements, please contact the corresponding manufacturer of Netapp for consultation.
