ONTAP Hardware
FAS 8200
Mitesh
Dear all,
1. Please help me regarding FAS 8200 cabling with disk self 2246(5p)
2. FAS 8200 to disk self ds212c and 4246(2p)
1 ACCEPTED SOLUTION
J_curl
Anything in particular you are having an issue with?  Check out the NetApp SAS and ACP Cabling Guide and the Install and Cabling Guide.  Everything you need to know, with example diagrams
4 REPLIES 4
J_curl
colsen
J_curl is right - check out the cabling/setup guides:
FAS8200 "poster":  https://library.netapp.com/ecm/ecm_download_file/ECMLP2316769
Oct2016 cabling guide:  https://library.netapp.com/ecm/ecm_get_file/ecmm1280392
Those are the best place to start.
Hope that helps,
Chris
Mitesh
Hi colsen,
Thanks for your quick reference..
Mitesh
hi all,
Please help me again. what is root disk and how to configure root disk in ontap 9 version. as per customer demand requied 6 root disk.
Usable Required
(TB)
Usable/RG (TB)Total RGs RequiredTotal Disks Required for UsableRoot Disks RequiredHot Spare 1 for 30 DisksTotal Disks Required
10026.154406248
