ONTAP Hardware
FAS affected by Meltdown and Spectre ?
MartINC
Does anyone knows if the meltdown and spectre security issues affect FAS systems, which uses Intel CPU ?
Will netapp release a new ontap release (ONTAP and 7-Mode) or firmwares ?
1 ACCEPTED SOLUTION
MartINC
You can find all the information related with meltdown and spectre vuln. in the following link provided by netapp support:
https://security.netapp.com/advisory/ntap-20180104-0001/
1 REPLY 1
MartINC
