ONTAP Hardware
FAS
dzekunskas
I wanted to know what the max flash cache is in the 8060?
1 REPLY 1
hariprak
Hi
The Maximum Flash Cache supported on FAS 8060 is 8TB. For further more details please refer http://www.netapp.com/us/products/storage-systems/fas8000/fas8000-product-comparison.aspx
Thanks
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
