ONTAP Hardware
FAS2020 FC Port and license questions
shadowmaster
Hi,
for some learning on small san boxes I wanted to buy an FAS2020 - I found one with some warranty,preformatted discs,  2x 4GB FC port and 2x ethernet
It comes with these licenses:
CIFS
FCP
HTTP
iSCSI
NFS
SNAPLOCK
SV_Applications_Pri
SyncMirror local
First question - does these licenses allow me to use the integrated ethernet port too for iSCSI, CIFS and NFS? I learned that FCP is the licese for the FC port.
second question: what type of port has this device? IS this FC or SFP+? Pls have a look at the attached image.
Until now I haven't touched such a device, my biggest NAS solution is a Synology DS414 at home... so forgive me with Netapp I am a newbie....
1 ACCEPTED SOLUTION
SpindleNinja
hwu.netapp.com is a good place to look up what's what physically on the systems.
#1 - Yes.
#2 - 0a 0b are the FC ports (check hwu!)  and show to be compatiable with sfp - X6539-R6
6 REPLIES 6
Sergey_Osipov
Here is link to documentation about this model
https://mysupport.netapp.com/documentation/docweb/index.html?productID=30324&language=en-US&archive=true
you can find all information there
shadowmaster
the documentation says it is "fibre channel"  but not the connector type...
SpindleNinja
#1 - Yes.
shadowmaster
and on hwu.nwtapp.com i cant go because I actually havent the rights yet... I will buy and register only when I know that I can use it
SpindleNinja
buy support?   There's no getting NetApp support on a 20xx box anymore.
I've mentioned the part # it's a SFP -> LC connector.
andris
Since we're nice folks here,  the X6359-R6 SFP part will have one of the following numbers on the label.
332-00333,
AFBR-57R6APZ-NA1,
AFBR-57R6APZ-NA2,
FTLF8524P2BNV-(N1)
