ONTAP Hardware
FAS2040 Console Port
CLOUDMINER
I have a FAS2040 being used as a NAS.  Should the console port be plugged into my physical switch or can it only be used to connect my laptop directly into it?
Thanks!
1 ACCEPTED SOLUTION
cgeck0000
The console port is just that... for serial console connection to a physical computer.
The FAS2040 does have an out-of-band management port called the BMC. This port has a wrench and is for SSH connectivity and out-of-band management of the unit to allow you to restart the controllers and not lose connectivity.
You can think of the BMC like a console port on the network.
2 REPLIES 2
cgeck0000
CLOUDMINER
OK great - thanks!
