ONTAP Hardware
FAS2220 re-build
HasayeretFMG
Hi guys,
I am totally new to Netapp and i just inharited a FAS2220 unit which was for some reason configured as NAS.
I'd like to re-build it and configure it as a SAN with RAID10, HA and all the goodies with the latest firmware for the controllers, disks and everything else.
I was already able to find an article on how to reboot the device and to reset it to factory defaulr via a console cable but i am not sure what to do before/after.
If there's a better way of re-configuring this device other than factory-reset it i would love to know.
Thanks!
3 REPLIES 3
Sahana
Hi,
You do not have to do factory reset. You can simple delete the existing vserver and create a new vserver and configure LUN for SAN. RAID 4, RAID DP are the only 2 options available. If you are creating a new aggregate you can select a RAID type. If using existing aggregate use aggregate modify to change the RAID type. I suggest upgrading to 8.3 Clustered Ontap and use advanced data partitioning feature to use the space efficiently. Refer https://www.netapp.com/us/media/tr-3982.pdf, https://library.netapp.com/ecmdocs/ECMP12458217/html/index.html
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
HasayeretFMG
@Sahana wrote:
Hi,
Thanks so much!
So the first step I assume would be to delete the vserver, correct? It's on the Netapp I assume? iIf so, would you mind explaining me how to do that and then how to configure the LUN for SAN?
Thanks so much for your help with this one!
Sahana
Hi,
https://library.netapp.com/ecmdocs/ECMP1636068/html/GUID-B559BDC0-59CE-4E97-ADDD-8575787247DC.html to delete vserver
Refer SAN configuration guide; https://library.netapp.com/ecmdocs/ECMP12458217/html/index.html
