ONTAP Hardware
FAS2240/2 Single controller issues
SIMON_TOMLINSON
Hi,
I've got a FAS2240/s setup with a single controller, with a DS4243 Shelf attached, populated with 24 x 1Tb SATA drives.
I've setup Ontap 8.2.1 7-mode, and configured everything as per recommended.
However, I have a couple of issues with regard to System Logs.
I constantly get 2 particular errors reported - The first one is 'Shelf 0a.shelf0 has Downrev Firmware'
I have checked the firmware versions, and they are up to date. The only issue I can spot is that for shelf 0, there is no 'B' controller firmware version listed (because there is no 'B' controller naturally).
The other error is probably related, in that there are messages complaining that shelf 0 has only got a single path to the disks.
Is there a way to suppress these errors, or have I configured something incorrectly?
1 ACCEPTED SOLUTION
aborzenkov
Sounds like a http://mysupport.netapp.com/NOW/cgi-bin/bol?Type=Detail&Display=813566; see also https://forums.netapp.com/thread/39503.
For mixed path - I believe this message should be generated only once, on reboot. I may be wrong though.
You could open case, quoting above bug for downrev problem. The more people complain, the more chances it will eventually be fixed.
12 REPLIES 12
aborzenkov
New systems should all have multipath shelf connection. You should connect second port as well.
SIMON_TOMLINSON
I am aware that shelves need to be multipathed, however the shelf that is being complained about is the controller shelf - there is no cabling to attach, its all internal.....
aborzenkov
OK, but do you have multipath connection to external shelf?
SIMON_TOMLINSON
The external shelf is multi-pathed. I've found a document which suggests that in a single controller config, access to the internal disks will be single path:
If this is correct then, shouldn't there be a way to stop it alerting, as it is correct?
aborzenkov
Yes, you need two controllers to have multipath connection to internal disks.
Could you paste exact messages?
SIMON_TOMLINSON
SIMON_TOMLINSON
SIMON_TOMLINSON
Shelf firmware report:
aborzenkov
It’s not what I mean under “paste”, but well … could you also check ACP firmware? It does not really tell which firmware is downrev.
SIMON_TOMLINSON
Alternate Control Path:          Enabled
Ethernet Interface:              e0P
ACP Status:                      Active
ACP IP Address:                  192.168.1.164
ACP Subnet:                      192.168.0.1
ACP Netmask:                     255.255.252.0
ACP Connectivity Status:         Full Connectivity
ACP Partner Connectivity Status: NA
Shelf Module      Reset Cnt    IP Address      FW Version   Module Type  Status
0a.10.B           000          192.168.1.119   02.08        IOM6         active
0a.10.A           000          192.168.1.73    02.08        IOM6         active
0a.00.A           000          192.168.2.223   01.20        IOM6E        active
aborzenkov
SIMON_TOMLINSON
Thanks, looks like that's the issue - I'll get a case reported, but wont hold my breath for a fix
