ONTAP Hardware
FAS2240 7Mode NFS VMware Datastore not empty?
Dieter
Hello,
I moved all vms to another Datastore.
old Datastore seems to be empty.
Snapshots are deleted.
the empty snapshotfolder is the only visible folder
toal capacitiy 800 GB
free capacity only 450GB
How is it possible to get the whole capacity?
4 REPLIES 4
Chris_
Hi Dieter,
maybe youre using snap reserve on this volume.
What is the output of:
snap reserve <volume>
or if you running cdot:
vol show -volume <volume> -fields percent-snapshot-space
If you have a 800GB volume with 50% snap reserve, you will see only 400GB.
Have a nice day.
Dieter
Hi,
Volume nfsstore1: current snapshot reserve is 1% or 8388608 k-bytes.
Dieter
Hello,
now,  after 48 hours the free space is ok.
is it possible that it took so much time to delete the snapshots?
Naveenpusuluru
Hi @Dieter
That depends up on the size and count of the snapshots. It will take some time to delete them.
