ONTAP Hardware
FAS250 Upgrade to FAS250C with add Shelf ?? Possilbe ??
vorname_nachname
Good Morning.
Im trying to finde a older Netapsystem to get some practice for my netapp certification.
Well iv found a FAS250 but i cant get some informations about a cluster version.
Is it possible to buye a FAS250 and buye also an additional controler and create so an A/A enviroment?
The other thing witch im unshure about is. Can i Attatch to a FAS250 an additional Shelf?
The Controller hase a Fiber interface but also here syes the System Configuration Document in the NOW there is no possibilty for additional shelfs.
The enviroment goes NOT Productional its only a playground enviroment for me and for testing.
Kind Regards
Florian
1 ACCEPTED SOLUTION
aborzenkov
FAS250 supports neither active/active nor additional shelves.
1 REPLY 1
aborzenkov
