ONTAP Hardware
FAS2552 UTA2 ports in 10GbE mode
MKELLYSCSC
Hi all,
I believe/hope that the answer to this question is Yes, but I really want clarification as the server in question is several hundred miles away in a different country.
We are moving the equipment to a new office in the next few weeks and taking the opportunity to do some network upgrades.
FAS2552
Data ONTAP 8.3.2P5
We have 2 free UTA2 ports (e0c & e0d) on each of the two nodes.
Will they work in 10GbE mode if I plug the correct SFP+ modules (X6589-R6 or equivalent) in?
I know that there are some issues relating to 1GbE support but I'm not worried about that.
Some output from sysconfig -A
        slot 0: Fibre Channel Target Host Adapter 0c
                (QLogic CNA 8324 (8362) rev. 2, <LINK NOT CONNECTED>)
                Firmware rev:      8.1.0
                Flash rev:         2.1.0
                Host Port Addr:    000000
                FC Nodename:       50:0a:09:80:80:f0:cb:ea (500a098080f0cbea)
                FC Portname:       50:0a:09:81:80:f0:cb:ea (500a098180f0cbea)
                Connection:        No link
                Switch Port:       Unknown
        slot 0: Fibre Channel Target Host Adapter 0d
                Firmware rev:      8.1.0
                Flash rev:         2.1.0
                FC Portname:       50:0a:09:82:80:f0:cb:ea (500a098280f0cbea)
                Connection:        No link
Many thanks for all help.
1 ACCEPTED SOLUTION
robinpeter
Answer is "Yes"
while in doubt, you can always check in hwu.netapp.com
here is a screenshot of the FAS2552 rear view. (from hwu.netapp.com)
If that wasn't clear, you can search for "Installation and Setup Instructions FAS2552 Systems" pdf file..
which will give you lil more cabling details.. (all this info plus a lot more.. is there in the hwu.netapp.com)
Hope that help
robin.
2 REPLIES 2
robinpeter
Answer is "Yes"
Hope that help
robin.
andris
In addition to changing to the correct 10GbE SFP's, you also need to ensure that the port pair is in the correct mode: CNA mode.  By default, the ports are in FC mode.
Use the command: system node hardware unified-connect modify
http://docs.netapp.com/ontap-9/topic/com.netapp.doc.dot-cm-cmpr-900/system__node__hardware__unified-connect__modify.html
Notes:
  1. The mode applies to both ports in the "pair" - for FAS2552, the port pairs are e0c/e0d and e0e/e0f (or for FC, 0c/0d and 0e/ef)
  2. After changing the mode, you must reboot the node for the change to take effect
After reboot, you can verify things are set up correctly:
  1. command: system node hardware unified-connect show
  2. sysconfig or sysconfig -a: you'll see e0c and e0d in the output, now.
