ONTAP Hardware
FAS2554 UTA2 Ports SFP+ Module requirement
jackychen1985
Hello,
Have anyone know the Netapp FAS2554 UTA2 Ports have any specific requirement for the SFP+ module?(I means if I purchase one other brand SFP+ moudule, it is possible to comptiable with UTA2 ports?)
Thanks in advanced!
1 REPLY 1
deepuj
Hi,
From Hardware universe :
The onboard UTA2 ports can be configured as FC Target/Initiator or CNA (FCoE target/Ethernet). The UTA2 ports are based on a dual port ASIC and both ports on each ASIC must be set to the same mode (enforced by Data ONTAP). Install X6589-R6 10GbE SFP+ modules or approved copper twinax cables when using in CNA (FCoE target/Ethernet) mode. Install X6596-R6 16Gb FC SFP+ module when using in FC Target/Initiator mode.
Thanks
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
