ONTAP Hardware
FAS2560 HA configuration
bahmed
Hello,
I have a new storage system FAS2650 with two controllers in same chassis and ontap 9.1, I want to know if there is an additional configuration to create a HA pair and cluster HA or the configuration is built-in by Netapp.    Thanks
1 ACCEPTED SOLUTION
Sahana
Hi,
It has built in configuration. Refer https://library.netapp.com/ecm/ecm_download_file/ECMLP2316768
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
1 REPLY 1
Sahana
Hi,
