ONTAP Hardware
FAS2650 EOSL
trackstar
Hello,
It looks like the date will be 05/31/2024.  We have two controllers.  We are interested in purchasing the the extended warranty.  Does that mean the storage array have the same EOSL.  Everywhere I read they referred to "FAS2650".  I am guessing its the complete system (if we buy the extended support).
Can someone confirm.
Thanks,
TT
1 ACCEPTED SOLUTION
andris
Support entitlement is tracked at the controller (system serial number) level. For a FAS2650 HA system (2 controllers), you would purchase the entitlement for both controllers and the underlying storage.
As @SpindleNinja pointed out, the support period that you can purchase might be shortened by old storage drives in the system, if those drives go "end of support" before the FAS2650 system's EOS date.
Reference: Support Services Terms
4 REPLIES 4
SpindleNinja
It's the controllers themselves and the capacity that is licensed with the associated drives.
Note though that drives can have a different EOL date than controllers.
trackstar
As long as the extended support covers the drive replacement, it will meet our needs.
SpindleNinja
Verity in the quote(s) with the account team.
There can be cases where the controller's date is past the drives, in past quotes for customers i've seen the drive model called out when it's not.
andris
