ONTAP Hardware
FAS2650 miniSAS Cable Connections - Need to Swap Ports
nicholsongc
What is the best supported way to swap SAS connections in production?
We currently have...
Node1:0a --> Node2:0a
Node1:0b-->Node2:0b
It should be...
Node1:0a --> Node2:0b
Node1:0b-->Node2:0a
I need to swap the connections on Node2 without causing a PANIC.  Any suggestions?
2 REPLIES 2
aborzenkov
Takeover, swap cables, giveback.
andris
That's a good, safe way to do it. You can also just yank the cables and recable while running.
Ref: Fault LED is lit for no apparent reason on a FAS22xx or FAS25xx HA storage system with internal-only storage
