ONTAP Hardware
FAS2650 serial port MAC client
Zubrania
Hello
Did anyone succeed in  connecting  Macbook  using  supplied with FAS2650 usb cable for initial installation  and troubleshooting ? Any  particular drivers to install ?
Thank you
1 ACCEPTED SOLUTION
D_BEREZENKO
There should be no problem with OSX to connect to NetApp using new micro-USB to USB-A cable
screen /dev/tty.usbserial 115200
1 REPLY 1
D_BEREZENKO
