ONTAP Hardware
FAS270 network module turned off
JOSEPHBOTROS
Hi,
This week all of a sudden we started to see disconnected mounts from the NAS. Looking at the logs I see
Thu Oct 20 16:00:00 GMT [raon-netapp1: kern.uptime.filer:info]:   4:00pm up  1 day, 16 mins, 366015 NFS ops, 0 CIFS ops, 0 HTTP ops, 0 DAFS ops, 0 FCP ops, 0 iSCSI ops
Thu Oct 20 16:00:00 GMT [raon-netapp1: statd:ALERT]: Cluster is licensed but takeover of partner is disabled
Thu Oct 20 16:32:43 GMT [raon-netapp1: cf.fsm.firmwareStatus:info]: Cluster monitor: partner halted
Thu Oct 20 16:32:44 GMT [raon-netapp1: cf.nm.nicViError:info]: Interconnect nic 0 has error on VI #4 SEND_DESC_ERROR 2
Thu Oct 20 16:32:44 GMT [raon-netapp1: cf.nm.nicTransitionDown:warning]: Interconnect link 0 is DOWN
Thu Oct 20 16:32:44 GMT [raon-netapp1: cf.rv.notConnected:error]: Connection for cfo_rv failed
Thu Oct 20 16:32:50 GMT [raon-netapp1: cf.fsm.partnerNotResponding:notice]: Cluster monitor: partner not responding
The network module LEDs are all off and the network activity LEDs are not flashing.
If I power cycle the appliance or re-seat the network module, it starts to work ok for a day or so.
After re-seating the module ....
Thu Oct 20 19:31:56 GMT [raon-netapp1: cf.nm.nicTransitionUp:info]: Interconnect link 0 is UP
Thu Oct 20 19:31:57 GMT [raon-netapp1: cf.fsm.firmwareStatus:info]: Cluster monitor: partner kernel loaded
Thu Oct 20 19:32:33 GMT [raon-netapp1: cf.fsm.partnerOk:notice]: Cluster monitor: partner ok
Thu Oct 20 19:32:33 GMT [raon-netapp1: cf.fsm.takeoverOfPartnerDisabled:notice]: Cluster monitor: takeover of raon-netapp2 disabled (partner booting)
Thu Oct 20 19:32:35 GMT [raon-netapp1: cf.fsm.takeoverOfPartnerEnabled:notice]: Cluster monitor: takeover of raon-netapp2 enabled
Thu Oct 20 19:32:35 GMT [raon-netapp1: cf.fsm.takeoverByPartnerEnabled:notice]: Cluster monitor: takeover of raon-netapp1 by raon-netapp2 enabled
Thu Oct 20 19:33:17 GMT [raon-netapp1: monitor.globalStatus.ok:info]: The system's global status is normal.
Does anyone know what is going on here. Any help will be appreciated.
Regards,
Joseph.
3 REPLIES 3
scottgelb
The cluster interconnect... which is implemented over Gigabit Ethernet but internally inside the DS14mk2 shelf.  Since reseating fixes it but it comes back, sounds like a hardware issue.  Either in the controller or shelf (shelf is passive so more likely the 270).  If you have support it would be worth an RMA on the controller.
JOSEPHBOTROS
Thanks, Scott.
I'll try to get in touch with NetApp and see if someone can come and look at it.
Regards,
Joseph.
nseries77
I am out of the office until 10/31/2011.
I will be out of the office visiting customers with limited access to phone
or email. I will be returning to the office on 10/31/2011.
If you have any questions or need immediate assist, please contact the
following:
Sushil U. Nanavati
IBM Technical Sales Specialist, Storage and System z East IMT
Phone/Fax 215-851-2019
[email protected]
Richard Swain - IBM N series Technical Resource Southeast
[email protected]
919.595.0838
Thnak you and have a great day.
Best regards,
Denis
Note: This is an automated response to your message ""FAS270 network
module turned off" "
sent on 10/27/2011 15:53:26.
This is the only notification you will receive while this person is away.
