ONTAP Hardware
FAS3140 Shelf Removal
alexthurston
Hello,
we have a FAS3140 that has 2 aggregates FC and SAS, im looking to remove the FC shelf rom there is no data on the aggregate currently, are the steps below correct or are we missing something
Remove volumes extported from aggregate
unassign disks from aggregate
delete aggregate
remove shelf
is it that easy?
Thanks
Alex
1 ACCEPTED SOLUTION
AlexDawson
Hot removing shelves requires that the system be running ONTAP 8.2.1 or later, otherwise the controller will panic (as it should if it detects a lot of drives suddenly missing).
The procedure for hot-removing shelves on ONTAP 8.2.1 is detailed at https://library.netapp.com/ecmdocs/ECMP1367947/html/GUID-2B80FBD2-007D-4D19-8EB1-9CCEED211001.html - but essentially it's what you have said, yes.
Hope this helps!
1 REPLY 1
AlexDawson
Hope this helps!
