ONTAP Hardware
FAS3160 downgrade to FAS3040
kwana
Hi,
Is it possible use FAS3040HA replace FAS3160HA controllers?
Regards,
Alex
2 REPLIES 2
thomas_glodde
If you have the same ammount of ports in your FAS3040, yes it is possible.
aborzenkov
Amount of ports does not really the main criterion. What matters, is
- Both filers run compatible Data ONTAP versions, so one can access disks taken from another
- Number of disks and shelves and total amount of storage do not exceed platform limit, taken in account of course how many shelves you can connect to a single loop and how many loops you can build (here is where number of ports starts to matter).
If all this is checked, it is trivial enough head swap.
