ONTAP Hardware
FAS3220 Dual Chassis HA interconnect error
unitech89e9
Hi everybody
I start to create a FAS3220 Dual Chassis HA enviroment,
but we don't have optional addition sas adapter,
so I decide to connect the controller to disk shelves by single path,
the topology just like that
but the cluster failover is not working,
when I use the cf status on each node,
the system show:
partner may be down, takeover disabled because of reason (partner mailbox disks not accessible or invalid)
FAS3220 has disabled takeover by partner (interconnect error)
RDMA Interconnect is down (Link 0 down).
When I use the cf monitor on each node,
the system show:
current time: 15Aug2014 04:19:51
UP 02:00:49, partner 'unknown', cluster monitor enabled
RDMA Interconnect is down (Link 0 down), takeover capability off-line (partner mailbox disks not accessible or invalid)
takeover by partner off-line (interconnect error)
partner may be down, last partner update UNKNOWN (15Aug2014 04:18:37)
When I use the cf hw_assist status
the system show
Local Node(FAS3220) Status:
        Inactive: FAS3220not monitoring alerts from partner(partner)
                Interconnect is down between nodes.
Partner Node(partner) Status:
        Can not read partner state
so I open the Oncommand System Manager to see the network interface
I see the the c0a and c0b is show the status like this
but I don't know where is my mistake?
what will make the interconnect port(c0a and c0b) be down?
Please help me!
Thanks very much
1 ACCEPTED SOLUTION
aborzenkov
Please boot into maintenance mode and use “ha-config show” to check current HA settings. Looks like your chassis is set to HA, which means it will disable external ports and try internal backplane connection.
11 REPLIES 11
DOMINIC_WYSS
it looks to me that you accidentally miscabled the interconnects. don't cross them out! c0a goes to c0a on the other head, not to c0b!
you get these link states (one interconnect up, the other down) when you crossed them out.
btw: if I remember correctly, it's now allowed to do ONE transition between IOM3 and IOM6 per stack (it was only allowed on FAS2000 series until recently).
so you can cable both shelf types into one stack and have it multipathed.
unitech89e9
Hi Dominic:
I cable the c0a on the other c0a,
and c0b to the other c0b,
is that wrong?
DOMINIC_WYSS
is that wrong?
no, that is correct. and also your schema is correct. but double check if you have not accidentally crossed the ports.
and check if you have the right cables! there are two types of these copper cables with the same SFP+ interface. I think the Ciscos do not work on the interconnect ports.
what's the output of these ports in sysconfig -a?
shane_bradley
Have you checked the disks are all visible from both nodes? could indicate that they cant see partner disks.
unitech89e9
Hi Shane:
I can sure that, every node can see all the disk!
unitech89e9
N6220-SAS> sysconfig -a
Data ONTAP Release 8.1.4P4 7-Mode: Sat Jun 28 01:52:51 PDT 2014
System ID: 2018635377 (N6220-SAS); partner ID: 2018730260 ()
System Serial Number: 2858C2513F009011 (N6220-SAS)
System Rev: B0
System Storage Configuration: Single-Path HA
System ACP Connectivity: NA
slot 0: System Board 2.3 GHz (System Board XVI B0)
                Model Name:         N6220
                Machine Type:       IBM-2858-C25
                Part Number:        111-01333
                Revision:           B0
                Serial Number:      9448935534
                BIOS version:       5.2.1
                Loader version:     3.4
                Processors:         4
                Processor ID:       0x1067a
                Microcode Version:  0xa0b
                Processor type:     Intel(R) Xeon(R) CPU           L5410  @ 2.33GHz
                Memory Size:        12288 MB
                Memory Attributes:  Bank Interleaving
                                    Hoisting
                                    Rank Interleaving
                                    Chipkill ECC
                NVMEM Size:         1600 MB of Main Memory Used
                CMOS RAM Status:    OK
Service Processor           Status: Online
  Firmware Version:   1.3.3
  Mgmt MAC Address:   00:A0:98:5A:FC:02
  Ethernet Link:      down
  Using DHCP:         yes
IPv4 configuration:
  IP Address:         unknown
  Netmask:            unknown
  Gateway:            unknown
IPv6 configuration:         Disabled
slot 0: Dual 10G Ethernet Controller T320E-SFP/KR
  Device Type:        CT-FE-3
  Version Number:     T3-SRAM1.1.0-BR1016-02-01-FW7.7.209-DR04
  Serial Number:     jb04050693
  c0a MAC Address:    00:a0:98:5a:fb:fe (auto-unknown-cfg_down)
  c0b MAC Address:    00:a0:98:5a:fb:ff (auto-unknown-enabling)
                        memory mapped I/O base 0xde801000, size 0x1000
                        memory mapped I/O base 0xde000000, size 0x800000
                        memory mapped I/O base 0xde800000, size 0x1000
slot 0: Internal BGE 10/100 Ethernet Controller
  e0M MAC Address:    00:a0:98:5a:fc:00 (auto-unknown-down)
  e0P MAC Address:    00:a0:98:5a:fc:01 (auto-100tx-fd-up)
                Device Type:        BCM5721
                        memory mapped I/O base 0xdf800000, size 0x10000
                        memory mapped I/O base 0xdf900000, size 0x10000
slot 0: Dual 10/100/1000 Ethernet Controller G20
  e0a MAC Address:    00:a0:98:5a:fb:fc (auto-1000t-fd-up)
  e0b MAC Address:    00:a0:98:5a:fb:fd (auto-unknown-down)
  Device Type:        Rev 6
                        memory mapped I/O base 0x00000000df720000, size 0x20000
                        memory mapped I/O base 0x00000000df700000, size 0x20000
                        I/O base 0x0000000000003000, size 0x20
                        memory mapped I/O base 0x00000000df760000, size 0x20000
                        memory mapped I/O base 0x00000000df740000, size 0x20000
                        I/O base 0x0000000000003020, size 0x20
slot 0: SAS Host Adapter 0a (PMC-Sierra PM8001 rev. C, SAS, <UP>)
  Firmware rev:       01.11.07.00
  Base WWN:           5:00a098:00364e4:08
  Phy State:          [0] Enabled, 6.0 Gb/s
                      [1] Enabled, 6.0 Gb/s
                      [2] Enabled, 6.0 Gb/s
                      [3] Enabled, 6.0 Gb/s
  QSFP Vendor:        Molex Inc.
  QSFP Part Number:   112-00177+A0
  QSFP Type:          Passive Copper 2m ID:00
  QSFP Serial Number: 408720176
                02.0 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB 512B/sect (P6J4DDSP)
                02.1 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB 512B/sect (P6J4GWPP)
                02.2 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB 512B/sect (P6J4PE1P)
                02.3 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB 512B/sect (P6J4LDNP)
                02.4 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB 512B/sect (P6J4K6KP)
                02.5 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB 512B/sect (P6J4689P)
                02.6 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB 512B/sect (P6J4GWRP)
                02.7 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB 512B/sect (P6J467YP)
                02.8 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB 512B/sect (P6J466VP)
                02.9 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB 512B/sect (P6J5053P)
                02.10: NETAPP   X306_HMRKP02TSSA NA00 1695.4GB 512B/sect (P6J4WVNP)
                02.11: NETAPP   X306_HMRKP02TSSA NA00 1695.4GB 512B/sect (P6J5044P)
                02.12: NETAPP   X306_HMRKP02TSSA NA00 1695.4GB 512B/sect (P6J504GP)
                03.0 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB 512B/sect (WD-WCC1P1277461)
                03.1 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB 512B/sect (WD-WCC1P1272876)
                03.2 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB 512B/sect (WD-WCC1P1274858)
                03.3 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB 512B/sect (WD-WCC1P1274741)
                03.4 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB 512B/sect (WD-WCC1P1274793)
                03.5 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB 512B/sect (WD-WCC1P1273338)
                03.6 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB 512B/sect (WD-WCC1P1271576)
                03.7 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB 512B/sect (WD-WCC1P1272160)
                03.8 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB 512B/sect (WD-WCC1P1273637)
                03.9 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB 512B/sect (WD-WCC1P1274446)
                03.10: NETAPP   X306_WKOJN02TSSA NA01 1695.4GB 512B/sect (WD-WCC1P1272310)
                03.11: NETAPP   X306_WKOJN02TSSA NA01 1695.4GB 512B/sect (WD-WCC1P1277264)
                03.12: NETAPP   X306_WKOJN02TSSA NA01 1695.4GB 512B/sect (WD-WCC1P1275875)
  Shelf   2: IOM6  Firmware rev. IOM6 A: 0162 IOM6 B: 0162
  Shelf   3: IOM6  Firmware rev. IOM6 A: 0162 IOM6 B: 0162
slot 0: SAS Host Adapter 0b (PMC-Sierra PM8001 rev. C, SAS, <UP>)
  Base WWN:           5:00a098:00364e4:0c
  Phy State:          [4] Enabled, 6.0 Gb/s
                      [5] Enabled, 6.0 Gb/s
                      [6] Enabled, 6.0 Gb/s
                      [7] Enabled, 6.0 Gb/s
  QSFP Serial Number: 408720154
                00.0 : NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGMJHWF)
                00.1 : NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGNZ2NF)
                00.2 : NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGG3YAM)
                00.3 : NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGNZ67F)
                00.4 : NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGJ7V4R)
                00.5 : NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGNYTGF)
                00.6 : NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGNZ2JF)
                00.7 : NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGMRH8M)
                00.8 : NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGMU9NM)
                00.9 : NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGMW1PM)
                00.10: NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGMT8XM)
                00.11: NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGMSGYM)
                00.12: NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGKNH0M)
                00.13: NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGK33SR)
                00.14: NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGMRPDM)
                00.15: NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGL17AM)
                00.16: NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGEX0XR)
                00.17: NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGMSYMM)
                00.18: NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGEJHVM)
                00.19: NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGMJ4UF)
                01.0 : NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44O0A0OCFUZ6)
                01.1 : NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44O0A0NJFUZ6)
                01.2 : NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44O0A0MRFUZ6)
                01.3 : NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44N0A058FUZ6)
                01.4 : NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44O0A0MBFUZ6)
                01.5 : NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44N0A055FUZ6)
                01.6 : NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44O0A0LMFUZ6)
                01.7 : NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44O0A0L4FUZ6)
                01.8 : NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44O0A0KOFUZ6)
                01.9 : NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44O0A0N7FUZ6)
                01.10: NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44N0A05BFUZ6)
                01.11: NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44N0A06YFUZ6)
                01.12: NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44M0A05RFUZ6)
                01.13: NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44M0A0ELFUZ6)
                01.14: NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44N0A0AXFUZ6)
                01.15: NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44N0A05JFUZ6)
                01.16: NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44M0A0EBFUZ6)
                01.17: NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44N0A04ZFUZ6)
                01.18: NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44N0A09JFUZ6)
                01.19: NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44M0A0E3FUZ6)
  Shelf   0: IOM6  Firmware rev. IOM6 A: 0162 IOM6 B: 0162
  Shelf   1: IOM6  Firmware rev. IOM6 A: 0162 IOM6 B: 0162
                        memory mapped I/O base 0xdf530000, size 0x10000
                        memory mapped I/O base 0xdf520000, size 0x10000
                        memory mapped I/O base 0x00000000df510000, size 0x10000
                        memory mapped I/O base 0x00000000df500000, size 0x10000
slot 0: FC Host Adapter 0c (QLogic 2432 rev. 2, N-port, <UP>)
  Firmware rev:      5.4.100
  Host Port Id:      0x10300
  FC Node Name:      5:00a:098003:64e400
  FC Port Name:      5:00a:098003:64e400
  SFP Vendor:        FINISAR CORP.
  SFP Part Number:   FTLF8524P2BNV
  SFP Serial Number: PQR1V3L
  SFP Capabilities:  1, 2 or 4 Gbit
  Link Data Rate:    4 Gbit
  Switch Port:       IBM_2498_B24:3
                        I/O base 0x0000000000002000, size 0x100
                        memory mapped I/O base 0xdf600000, size 0x4000
slot 0: FC Host Adapter 0d (QLogic 2432 rev. 2, N-port, <UP>)
  FC Node Name:      5:00a:098103:64e400
  FC Port Name:      5:00a:098103:64e400
  SFP Serial Number: PQS0QLZ
                        I/O base 0x0000000000002400, size 0x100
                        memory mapped I/O base 0xdf604000, size 0x4000
slot 0: Intel ICH USB EHCI Adapter u0a (0xdfa01400)
  boot0 Micron Technology 0x655, class 0/0, rev 2.00/11.10, addr 2 1936MB 512B/sect (2DF0022700016909)
                        memory-mapped I/O base 0xdfa01400, size 0x400
slot 1: FC Host Adapter 1a (QLogic 2532 rev. 2, L-port, <OFFLINE (hard)>)
  Board name:        QLE2564
  Serial Number:     RFD1404U23108
  Firmware rev:      5.4.130
  Host Loop Id:      0
  FC Node Name:      2:000:0024ff:731854
  FC Port Name:      2:100:0024ff:731854
  SFP Vendor:        AVAGO
  SFP Part Number:   AFBR-57D9AMZ-QL
  SFP Serial Number: AD13393043V
  SFP Capabilities:  2, 4 or 8 Gbit
  Link Data Rate:    N/A
                        I/O base 0x00000000ffffff00, size 0x100
                        memory mapped I/O base 0xdee00000, size 0x4000
                        memory mapped I/O base 0xdec00000, size 0x100000
slot 1: FC Host Adapter 1b (QLogic 2532 rev. 2, L-port, <OFFLINE (hard)>)
  Board name:        QLE2564
  Host Loop Id:      0
  FC Node Name:      2:000:0024ff:731855
  FC Port Name:      2:100:0024ff:731855
  SFP Vendor:        AVAGO
  SFP Serial Number: AD13393043X
  Link Data Rate:    N/A
                        memory mapped I/O base 0xdee04000, size 0x4000
                        memory mapped I/O base 0xded00000, size 0x100000
slot 1: FC Host Adapter 1c (QLogic 2532 rev. 2, L-port, <OFFLINE (hard)>)
  Board name:        QLE2564
  Host Loop Id:      0
  FC Node Name:      2:000:0024ff:731856
  FC Port Name:      2:100:0024ff:731856
  SFP Vendor:        AVAGO
  SFP Serial Number: AD13393043Y
  Link Data Rate:    N/A
                        memory mapped I/O base 0xdf100000, size 0x4000
                        memory mapped I/O base 0xdef00000, size 0x100000
slot 1: FC Host Adapter 1d (QLogic 2532 rev. 2, L-port, <OFFLINE (hard)>)
  Board name:        QLE2564
  Host Loop Id:      0
  FC Node Name:      2:000:0024ff:731857
  FC Port Name:      2:100:0024ff:731857
  SFP Vendor:        AVAGO
  SFP Serial Number: AD13393043U
  Link Data Rate:    N/A
                        memory mapped I/O base 0xdf104000, size 0x4000
                        memory mapped I/O base 0xdf000000, size 0x100000
slot 2: FCVI Host Adapter 2a (QLogic 2532(2562) rev. 2, unknown, <DOWN>)
  Physical link: DOWN
  FC Node Name: 21:00:00:24:ff:58:4f:58
  Firmware rev: 5.3.140 Serial No: BFD1408T29623
  Host Port Id: 0xffffffff
  Cacheline size: 8 FC Packet size: 2048
  SFP Part Number: FTLF8528P3BCV-QL
  SFP Serial Number: PR11JG5
                        memory mapped I/O base 0xdf200000, size 0x4000
slot 2: FCVI Host Adapter 2b (QLogic 2532(2562) rev. 2, unknown, <DOWN>)
  Physical link: DOWN
  FC Node Name: 21:00:00:24:ff:58:4f:59
  SFP Serial Number: PR11JFW
                        memory mapped I/O base 0xdf204000, size 0x4000
unitech89e9
rdfile /etc/log/messages
Sun Aug 17 00:19:34 GMT [N6220-SAS:callhome.management.log:info]: Call home for MANAGEMENT_LOG
Sun Aug 17 00:19:34 GMT [N6220-SAS:callhome.weekly:info]: Call home for WEEKLY_LOG
Sun Aug 17 00:19:35 GMT [N6220-SAS:kern.log.rotate:notice]: System N6220-SAS (ID 2018635377) is running 8.1.4P4
Sun Aug 17 00:56:11 GMT [N6220-SAS:asup.post.drop:error]: AutoSupport message (HA Group Notification from N6220-SAS (PERFORMANCE DATA) INFO) for host (0) was not posted to IBM. The system will drop the message.
Sun Aug 17 01:00:00 GMT [N6220-SAS:kern.uptime.filer:info]:   1:00am up  1 day, 22:40 0 NFS ops, 196 CIFS ops, 0 HTTP ops, 0 FCP ops, 0 iSCSI ops
Sun Aug 17 01:00:03 GMT [N6220-SAS:raid.rg.scrub.start:notice]: /aggr0/plex0/rg2: starting scrub
Sun Aug 17 01:00:04 GMT [N6220-SAS:cf.takeover.disabled:warning]: Controller Failover is licensed but takeover of partner is disabled due to reason : partner mailbox disks not accessible or invalid.
Sun Aug 17 01:00:04 GMT [N6220-SAS:cf.ic.hourlyBackplaneLinkDownTime:error]: Backplane Interconnect link has been down for 2801 minutes
Sun Aug 17 01:00:04 GMT [N6220-SAS:raid.rg.scrub.start:notice]: /aggr0/plex0/rg1: starting scrub
Sun Aug 17 01:00:05 GMT [N6220-SAS:raid.rg.scrub.start:notice]: /aggr0/plex0/rg0: starting scrub
Sun Aug 17 01:56:16 GMT [N6220-SAS:asup.post.drop:error]: AutoSupport message (HA Group Notification from N6220-SAS (MANAGEMENT_LOG) INFO) for host (0) was not posted to IBM. The system will drop the message.
Sun Aug 17 02:00:00 GMT [N6220-SAS:kern.uptime.filer:info]:   2:00am up  1 day, 23:40 0 NFS ops, 196 CIFS ops, 0 HTTP ops, 0 FCP ops, 0 iSCSI ops
Sun Aug 17 02:00:04 GMT [N6220-SAS:cf.takeover.disabled:warning]: Controller Failover is licensed but takeover of partner is disabled due to reason : partner mailbox disks not accessible or invalid.
Sun Aug 17 02:00:04 GMT [N6220-SAS:cf.ic.hourlyBackplaneLinkDownTime:error]: Backplane Interconnect link has been down for 2861 minutes
Sun Aug 17 02:56:26 GMT [N6220-SAS:asup.post.drop:error]: AutoSupport message (HA Group Notification from N6220-SAS (WEEKLY_LOG) INFO) for host (0) was not posted to IBM. The system will drop the message.
Sun Aug 17 03:00:00 GMT [N6220-SAS:kern.uptime.filer:info]:   3:00am up  2 days, 40 mins, 0 NFS ops, 196 CIFS ops, 0 HTTP ops, 0 FCP ops, 0 iSCSI ops
Sun Aug 17 03:00:04 GMT [N6220-SAS:cf.takeover.disabled:warning]: Controller Failover is licensed but takeover of partner is disabled due to reason : partner mailbox disks not accessible or invalid.
Sun Aug 17 03:00:04 GMT [N6220-SAS:cf.ic.hourlyBackplaneLinkDownTime:error]: Backplane Interconnect link has been down for 2921 minutes
Sun Aug 17 04:00:00 GMT [N6220-SAS:kern.uptime.filer:info]:   4:00am up  2 days,  1:40 0 NFS ops, 196 CIFS ops, 0 HTTP ops, 0 FCP ops, 0 iSCSI ops
Sun Aug 17 04:00:04 GMT [N6220-SAS:cf.takeover.disabled:warning]: Controller Failover is licensed but takeover of partner is disabled due to reason : partner mailbox disks not accessible or invalid.
Sun Aug 17 04:00:04 GMT [N6220-SAS:cf.ic.hourlyBackplaneLinkDownTime:error]: Backplane Interconnect link has been down for 2981 minutes
Sun Aug 17 04:35:21 GMT [N6220-SAS:raid.rg.scrub.done:notice]: /aggr0/plex0/rg2: scrub completed in 3:35:17.00
Sun Aug 17 04:35:21 GMT [N6220-SAS:raid.rg.scrub.summary.pi:notice]: Scrub found 0 parity inconsistencies in /aggr0/plex0/rg2.
Sun Aug 17 04:35:21 GMT [N6220-SAS:raid.rg.scrub.summary.cksum:notice]: Scrub found 0 checksum errors in /aggr0/plex0/rg2.
Sun Aug 17 04:35:21 GMT [N6220-SAS:raid.rg.scrub.summary.media:notice]: Scrub found 0 media errors in /aggr0/plex0/rg2.
Sun Aug 17 04:35:21 GMT [N6220-SAS:raid.rg.scrub.summary.lw:notice]: Scrub found 0 RAID write signature inconsistencies in /aggr0/plex0/rg2.
Sun Aug 17 05:00:00 GMT [N6220-SAS:kern.uptime.filer:info]:   5:00am up  2 days,  2:40 0 NFS ops, 196 CIFS ops, 0 HTTP ops, 0 FCP ops, 0 iSCSI ops
Sun Aug 17 05:00:04 GMT [N6220-SAS:cf.takeover.disabled:warning]: Controller Failover is licensed but takeover of partner is disabled due to reason : partner mailbox disks not accessible or invalid.
Sun Aug 17 05:00:04 GMT [N6220-SAS:cf.ic.hourlyBackplaneLinkDownTime:error]: Backplane Interconnect link has been down for 3041 minutes
Sun Aug 17 05:39:58 GMT [N6220-SAS:raid.rg.scrub.done:notice]: /aggr0/plex0/rg1: scrub completed in 4:39:53.00
Sun Aug 17 05:39:58 GMT [N6220-SAS:raid.rg.scrub.summary.pi:notice]: Scrub found 0 parity inconsistencies in /aggr0/plex0/rg1.
Sun Aug 17 05:39:58 GMT [N6220-SAS:raid.rg.scrub.summary.cksum:notice]: Scrub found 0 checksum errors in /aggr0/plex0/rg1.
Sun Aug 17 05:39:58 GMT [N6220-SAS:raid.rg.scrub.summary.media:notice]: Scrub found 0 media errors in /aggr0/plex0/rg1.
Sun Aug 17 05:39:58 GMT [N6220-SAS:raid.rg.scrub.summary.lw:notice]: Scrub found 0 RAID write signature inconsistencies in /aggr0/plex0/rg1.
Sun Aug 17 06:00:00 GMT [N6220-SAS:kern.uptime.filer:info]:   6:00am up  2 days,  3:40 0 NFS ops, 196 CIFS ops, 0 HTTP ops, 0 FCP ops, 0 iSCSI ops
Sun Aug 17 06:00:04 GMT [N6220-SAS:cf.takeover.disabled:warning]: Controller Failover is licensed but takeover of partner is disabled due to reason : partner mailbox disks not accessible or invalid.
Sun Aug 17 06:00:04 GMT [N6220-SAS:cf.ic.hourlyBackplaneLinkDownTime:error]: Backplane Interconnect link has been down for 3101 minutes
Sun Aug 17 06:44:41 GMT [N6220-SAS:raid.rg.scrub.done:notice]: /aggr0/plex0/rg0: scrub completed in 5:44:36.00
Sun Aug 17 06:44:41 GMT [N6220-SAS:raid.rg.scrub.summary.pi:notice]: Scrub found 0 parity inconsistencies in /aggr0/plex0/rg0.
Sun Aug 17 06:44:41 GMT [N6220-SAS:raid.rg.scrub.summary.cksum:notice]: Scrub found 0 checksum errors in /aggr0/plex0/rg0.
Sun Aug 17 06:44:41 GMT [N6220-SAS:raid.rg.scrub.summary.media:notice]: Scrub found 0 media errors in /aggr0/plex0/rg0.
Sun Aug 17 06:44:41 GMT [N6220-SAS:raid.rg.scrub.summary.lw:notice]: Scrub found 0 RAID write signature inconsistencies in /aggr0/plex0/rg0.
Sun Aug 17 07:00:00 GMT [N6220-SAS:kern.uptime.filer:info]:   7:00am up  2 days,  4:40 0 NFS ops, 196 CIFS ops, 0 HTTP ops, 0 FCP ops, 0 iSCSI ops
Sun Aug 17 07:00:04 GMT [N6220-SAS:cf.takeover.disabled:warning]: Controller Failover is licensed but takeover of partner is disabled due to reason : partner mailbox disks not accessible or invalid.
Sun Aug 17 07:00:04 GMT [N6220-SAS:cf.ic.hourlyBackplaneLinkDownTime:error]: Backplane Interconnect link has been down for 3161 minutes
Sun Aug 17 08:00:00 GMT [N6220-SAS:kern.uptime.filer:info]:   8:00am up  2 days,  5:40 0 NFS ops, 196 CIFS ops, 0 HTTP ops, 0 FCP ops, 0 iSCSI ops
Sun Aug 17 08:00:04 GMT [N6220-SAS:cf.takeover.disabled:warning]: Controller Failover is licensed but takeover of partner is disabled due to reason : partner mailbox disks not accessible or invalid.
Sun Aug 17 08:00:04 GMT [N6220-SAS:cf.ic.hourlyBackplaneLinkDownTime:error]: Backplane Interconnect link has been down for 3221 minutes
Sun Aug 17 09:00:00 GMT [N6220-SAS:kern.uptime.filer:info]:   9:00am up  2 days,  6:40 0 NFS ops, 196 CIFS ops, 0 HTTP ops, 0 FCP ops, 0 iSCSI ops
Sun Aug 17 09:00:04 GMT [N6220-SAS:cf.takeover.disabled:warning]: Controller Failover is licensed but takeover of partner is disabled due to reason : partner mailbox disks not accessible or invalid.
Sun Aug 17 09:00:04 GMT [N6220-SAS:cf.ic.hourlyBackplaneLinkDownTime:error]: Backplane Interconnect link has been down for 3281 minutes
Sun Aug 17 10:00:00 GMT [N6220-SAS:kern.uptime.filer:info]:  10:00am up  2 days,  7:40 0 NFS ops, 196 CIFS ops, 0 HTTP ops, 0 FCP ops, 0 iSCSI ops
Sun Aug 17 10:00:04 GMT [N6220-SAS:cf.takeover.disabled:warning]: Controller Failover is licensed but takeover of partner is disabled due to reason : partner mailbox disks not accessible or invalid.
Sun Aug 17 10:00:04 GMT [N6220-SAS:cf.ic.hourlyBackplaneLinkDownTime:error]: Backplane Interconnect link has been down for 3341 minutes
Sun Aug 17 11:00:00 GMT [N6220-SAS:kern.uptime.filer:info]:  11:00am up  2 days,  8:40 0 NFS ops, 196 CIFS ops, 0 HTTP ops, 0 FCP ops, 0 iSCSI ops
Sun Aug 17 11:00:04 GMT [N6220-SAS:cf.takeover.disabled:warning]: Controller Failover is licensed but takeover of partner is disabled due to reason : partner mailbox disks not accessible or invalid.
Sun Aug 17 11:00:04 GMT [N6220-SAS:cf.ic.hourlyBackplaneLinkDownTime:error]: Backplane Interconnect link has been down for 3401 minutes
Sun Aug 17 12:00:00 GMT [N6220-SAS:kern.uptime.filer:info]:  12:00pm up  2 days,  9:40 0 NFS ops, 196 CIFS ops, 0 HTTP ops, 0 FCP ops, 0 iSCSI ops
Sun Aug 17 12:00:04 GMT [N6220-SAS:cf.takeover.disabled:warning]: Controller Failover is licensed but takeover of partner is disabled due to reason : partner mailbox disks not accessible or invalid.
Sun Aug 17 12:00:04 GMT [N6220-SAS:cf.ic.hourlyBackplaneLinkDownTime:error]: Backplane Interconnect link has been down for 3461 minutes
Sun Aug 17 13:00:00 GMT [N6220-SAS:kern.uptime.filer:info]:   1:00pm up  2 days, 10:40 0 NFS ops, 196 CIFS ops, 0 HTTP ops, 0 FCP ops, 0 iSCSI ops
Sun Aug 17 13:00:04 GMT [N6220-SAS:cf.takeover.disabled:warning]: Controller Failover is licensed but takeover of partner is disabled due to reason : partner mailbox disks not accessible or invalid.
Sun Aug 17 13:00:04 GMT [N6220-SAS:cf.ic.hourlyBackplaneLinkDownTime:error]: Backplane Interconnect link has been down for 3521 minutes
Sun Aug 17 14:00:00 GMT [N6220-SAS:kern.uptime.filer:info]:   2:00pm up  2 days, 11:40 0 NFS ops, 196 CIFS ops, 0 HTTP ops, 0 FCP ops, 0 iSCSI ops
Sun Aug 17 14:00:04 GMT [N6220-SAS:cf.takeover.disabled:warning]: Controller Failover is licensed but takeover of partner is disabled due to reason : partner mailbox disks not accessible or invalid.
Sun Aug 17 14:00:04 GMT [N6220-SAS:cf.ic.hourlyBackplaneLinkDownTime:error]: Backplane Interconnect link has been down for 3581 minutes
Sun Aug 17 15:00:00 GMT [N6220-SAS:kern.uptime.filer:info]:   3:00pm up  2 days, 12:40 0 NFS ops, 196 CIFS ops, 0 HTTP ops, 0 FCP ops, 0 iSCSI ops
Sun Aug 17 15:00:04 GMT [N6220-SAS:cf.takeover.disabled:warning]: Controller Failover is licensed but takeover of partner is disabled due to reason : partner mailbox disks not accessible or invalid.
Sun Aug 17 15:00:04 GMT [N6220-SAS:cf.ic.hourlyBackplaneLinkDownTime:error]: Backplane Interconnect link has been down for 3641 minutes
Sun Aug 17 16:00:00 GMT [N6220-SAS:kern.uptime.filer:info]:   4:00pm up  2 days, 13:40 0 NFS ops, 196 CIFS ops, 0 HTTP ops, 0 FCP ops, 0 iSCSI ops
Sun Aug 17 16:00:04 GMT [N6220-SAS:cf.takeover.disabled:warning]: Controller Failover is licensed but takeover of partner is disabled due to reason : partner mailbox disks not accessible or invalid.
Sun Aug 17 16:00:04 GMT [N6220-SAS:cf.ic.hourlyBackplaneLinkDownTime:error]: Backplane Interconnect link has been down for 3701 minutes
Sun Aug 17 17:00:00 GMT [N6220-SAS:kern.uptime.filer:info]:   5:00pm up  2 days, 14:40 0 NFS ops, 196 CIFS ops, 0 HTTP ops, 0 FCP ops, 0 iSCSI ops
Sun Aug 17 17:00:04 GMT [N6220-SAS:cf.takeover.disabled:warning]: Controller Failover is licensed but takeover of partner is disabled due to reason : partner mailbox disks not accessible or invalid.
Sun Aug 17 17:00:04 GMT [N6220-SAS:cf.ic.hourlyBackplaneLinkDownTime:error]: Backplane Interconnect link has been down for 3761 minutes
Sun Aug 17 18:00:00 GMT [N6220-SAS:kern.uptime.filer:info]:   6:00pm up  2 days, 15:40 0 NFS ops, 196 CIFS ops, 0 HTTP ops, 0 FCP ops, 0 iSCSI ops
Sun Aug 17 18:00:04 GMT [N6220-SAS:cf.takeover.disabled:warning]: Controller Failover is licensed but takeover of partner is disabled due to reason : partner mailbox disks not accessible or invalid.
Sun Aug 17 18:00:04 GMT [N6220-SAS:cf.ic.hourlyBackplaneLinkDownTime:error]: Backplane Interconnect link has been down for 3821 minutes
Sun Aug 17 19:00:00 GMT [N6220-SAS:kern.uptime.filer:info]:   7:00pm up  2 days, 16:40 0 NFS ops, 196 CIFS ops, 0 HTTP ops, 0 FCP ops, 0 iSCSI ops
Sun Aug 17 19:00:04 GMT [N6220-SAS:cf.takeover.disabled:warning]: Controller Failover is licensed but takeover of partner is disabled due to reason : partner mailbox disks not accessible or invalid.
Sun Aug 17 19:00:04 GMT [N6220-SAS:cf.ic.hourlyBackplaneLinkDownTime:error]: Backplane Interconnect link has been down for 3881 minutes
Sun Aug 17 20:00:00 GMT [N6220-SAS:kern.uptime.filer:info]:   8:00pm up  2 days, 17:40 0 NFS ops, 196 CIFS ops, 0 HTTP ops, 0 FCP ops, 0 iSCSI ops
Sun Aug 17 20:00:04 GMT [N6220-SAS:cf.takeover.disabled:warning]: Controller Failover is licensed but takeover of partner is disabled due to reason : partner mailbox disks not accessible or invalid.
Sun Aug 17 20:00:04 GMT [N6220-SAS:cf.ic.hourlyBackplaneLinkDownTime:error]: Backplane Interconnect link has been down for 3941 minutes
Sun Aug 17 21:00:00 GMT [N6220-SAS:kern.uptime.filer:info]:   9:00pm up  2 days, 18:40 0 NFS ops, 196 CIFS ops, 0 HTTP ops, 0 FCP ops, 0 iSCSI ops
Sun Aug 17 21:00:04 GMT [N6220-SAS:cf.takeover.disabled:warning]: Controller Failover is licensed but takeover of partner is disabled due to reason : partner mailbox disks not accessible or invalid.
Sun Aug 17 21:00:04 GMT [N6220-SAS:cf.ic.hourlyBackplaneLinkDownTime:error]: Backplane Interconnect link has been down for 4001 minutes
Sun Aug 17 21:46:17 GMT [console_login_mgr:info]: root logged in from console
Sun Aug 17 21:46:25 GMT [N6220-SAS:cf.misc.operatorDisable:warning]: Failover monitor: operator initiated disabling of takeover
Sun Aug 17 21:46:26 GMT [N6220-SAS:cf.fsm.takeoverOfPartnerDisabled:notice]: Failover monitor: takeover of partner disabled (Controller Failover takeover disabled).
Sun Aug 17 21:46:26 GMT [N6220-SAS:cf.fsm.takeoverByPartnerDisabled:notice]: Failover monitor: takeover of N6220-SAS by partner disabled (Controller Failover takeover disabled).
Sun Aug 17 21:58:16 GMT [rc:notice]: The system was down for 662 seconds
Sun Aug 17 21:48:53 GMT [N6220-SAS:fci.adapter.link.online:info]: Fibre Channel adapter 0c link online.
Sun Aug 17 21:48:53 GMT [N6220-SAS:fci.adapter.link.online:info]: Fibre Channel adapter 0d link online.
Sun Aug 17 21:48:54 GMT [N6220-SAS:mlm.array.portEmpty.switch:info]: Fibre Channel host bus adapter 0c reports no LUNs presented by storage array IBM_2145_?, target port WWNN: 5005076803004110 WWPN: 5005076803044110, switch:port IBM_2498_B24:0.
Sun Aug 17 21:48:54 GMT [N6220-SAS:mlm.array.portEmpty.switch:info]: Fibre Channel host bus adapter 0c reports no LUNs presented by storage array IBM_2145_?, target port WWNN: 5005076803004111 WWPN: 5005076803044111, switch:port IBM_2498_B24:1.
Sun Aug 17 21:48:54 GMT [N6220-SAS:mlm.array.portEmpty.switch:info]: Fibre Channel host bus adapter 0d reports no LUNs presented by storage array IBM_2145_?, target port WWNN: 5005076803004111 WWPN: 5005076803084111, switch:port IBM_2498_B24:1.
Sun Aug 17 21:48:54 GMT [N6220-SAS:mlm.array.portEmpty.switch:info]: Fibre Channel host bus adapter 0d reports no LUNs presented by storage array IBM_2145_?, target port WWNN: 5005076803004110 WWPN: 5005076803084110, switch:port IBM_2498_B24:0.
Sun Aug 17 21:48:59 GMT [N6220-SAS:fci.initialization.failed:error]: Initialization failed on Fibre Channel adapter 1a.
Sun Aug 17 21:48:59 GMT [N6220-SAS:fci.initialization.failed:error]: Initialization failed on Fibre Channel adapter 1b.
Sun Aug 17 21:48:59 GMT [N6220-SAS:fci.initialization.failed:error]: Initialization failed on Fibre Channel adapter 1d.
Sun Aug 17 21:48:59 GMT [N6220-SAS:fci.initialization.failed:error]: Initialization failed on Fibre Channel adapter 1c.
Sun Aug 17 21:49:00 GMT [N6220-SAS:netif.linkDown:info]: Ethernet Wrench Port: Link down, check cable.
Sun Aug 17 21:49:05 GMT [N6220-SAS:diskown.isEnabled:info]: software ownership has been enabled for this system
Sun Aug 17 21:49:05 GMT [N6220-SAS:dcs.framework.enabled:info]: The DCS framework is enabled on this node.
Sun Aug 17 21:49:07 GMT [N6220-SAS:wafl.memory.status:info]: 7092MB of memory is currently available for the WAFL file system.
Sun Aug 17 21:49:09 GMT [N6220-SAS:shelf.config.spha:info]: System is using single path HA attached storage only.
Sun Aug 17 21:49:09 GMT [N6220-SAS:netif.linkUp:info]: Ethernet e0P: Link up.
Sun Aug 17 21:49:10 GMT [N6220-SAS:ses.multipath.ReqError:CRITICAL]: SAS-Shelf24 detected without a multipath configuration.
Sun Aug 17 21:49:11 GMT [N6220-SAS:mgr.boot.reason_ok:notice]: System rebooted after a reboot command.
Sun Aug 17 21:49:11 GMT [N6220-SAS:callhome.reboot.reboot:info]: Call home for REBOOT (reboot command)
Sun Aug 17 21:49:12 GMT [N6220-SAS:netif.linkDown:info]: Ethernet e0b: Link down, check cable.
Sun Aug 17 21:49:12 GMT [N6220-SAS:netif.linkDown:info]: Ethernet e0a: Link down, check cable.
Sun Aug 17 21:49:14 GMT [N6220-SAS:netif.linkUp:info]: Ethernet e0P: Link up.
Sun Aug 17 21:49:14 GMT [N6220-SAS:netif.linkDown:info]: Ethernet e0M: Link down, check cable.
Sun Aug 17 21:50:27 GMT [N6220-SAS:fci.link.break:error]: Link break detected on Fibre Channel adapter 0c.
Sun Aug 17 21:50:58 GMT [N6220-SAS:fci.link.error:error]: Could not recover link on Fibre Channel adapter 0c after 30 seconds. Offlining the adapter.
Sun Aug 17 21:51:41 GMT [N6220-SAS:fci.adapter.link.online:info]: Fibre Channel adapter 0c link online.
Sun Aug 17 21:51:41 GMT [N6220-SAS:fci.adapter.online:info]: Fibre Channel adapter 0c is now online.
Sun Aug 17 21:51:41 GMT [N6220-SAS:mlm.array.portEmpty.switch:info]: Fibre Channel host bus adapter 0c reports no LUNs presented by storage array IBM_2145_?, target port WWNN: 5005076803004110 WWPN: 5005076803044110, switch:port IBM_2498_B24:0.
Sun Aug 17 21:51:41 GMT [N6220-SAS:mlm.array.portEmpty.switch:info]: Fibre Channel host bus adapter 0c reports no LUNs presented by storage array IBM_2145_?, target port WWNN: 5005076803004111 WWPN: 5005076803044111, switch:port IBM_2498_B24:1.
Sun Aug 17 21:57:59 GMT [N6220-SAS:fci.adapter.link.online:info]: Fibre Channel adapter 0c link online.
Sun Aug 17 21:57:59 GMT [N6220-SAS:fci.adapter.link.online:info]: Fibre Channel adapter 0d link online.
Sun Aug 17 21:57:59 GMT [N6220-SAS:mlm.array.portEmpty.switch:info]: Fibre Channel host bus adapter 0c reports no LUNs presented by storage array IBM_2145_?, target port WWNN: 5005076803004110 WWPN: 5005076803044110, switch:port IBM_2498_B24:0.
Sun Aug 17 21:57:59 GMT [N6220-SAS:mlm.array.portEmpty.switch:info]: Fibre Channel host bus adapter 0c reports no LUNs presented by storage array IBM_2145_?, target port WWNN: 5005076803004111 WWPN: 5005076803044111, switch:port IBM_2498_B24:1.
Sun Aug 17 21:57:59 GMT [N6220-SAS:mlm.array.portEmpty.switch:info]: Fibre Channel host bus adapter 0d reports no LUNs presented by storage array IBM_2145_?, target port WWNN: 5005076803004110 WWPN: 5005076803084110, switch:port IBM_2498_B24:0.
Sun Aug 17 21:57:59 GMT [N6220-SAS:mlm.array.portEmpty.switch:info]: Fibre Channel host bus adapter 0d reports no LUNs presented by storage array IBM_2145_?, target port WWNN: 5005076803004111 WWPN: 5005076803084111, switch:port IBM_2498_B24:1.
Sun Aug 17 21:58:05 GMT [N6220-SAS:fci.initialization.failed:error]: Initialization failed on Fibre Channel adapter 1a.
Sun Aug 17 21:58:05 GMT [N6220-SAS:fci.initialization.failed:error]: Initialization failed on Fibre Channel adapter 1b.
Sun Aug 17 21:58:05 GMT [N6220-SAS:fci.initialization.failed:error]: Initialization failed on Fibre Channel adapter 1c.
Sun Aug 17 21:58:05 GMT [N6220-SAS:fci.initialization.failed:error]: Initialization failed on Fibre Channel adapter 1d.
Sun Aug 17 21:58:05 GMT [N6220-SAS:netif.linkDown:info]: Ethernet Wrench Port: Link down, check cable.
Sun Aug 17 21:58:11 GMT [N6220-SAS:diskown.isEnabled:info]: software ownership has been enabled for this system
Sun Aug 17 21:58:11 GMT [N6220-SAS:dcs.framework.enabled:info]: The DCS framework is enabled on this node.
Sun Aug 17 21:58:11 GMT [N6220-SAS:config.noPartnerDisks:CRITICAL]: No disks were detected for the partner; this node will be unable to takeover correctly
Sun Aug 17 21:58:11 GMT [N6220-SAS:callhome.dsk.config:warning]: Call home for DISK CONFIGURATION ERROR
Sun Aug 17 21:58:13 GMT [N6220-SAS:wafl.memory.status:info]: 7070MB of memory is currently available for the WAFL file system.
Sun Aug 17 21:58:13 GMT [N6220-SAS:fmmb.instStat.change:info]: no mailbox instance on local side.
Sun Aug 17 21:58:13 GMT [N6220-SAS:fmmb.instStat.change:info]: no mailbox instance on partner side.
Sun Aug 17 21:58:13 GMT [N6220-SAS:cf.fm.noMBDisksOrIc:warning]: Could not find the local mailbox disks. Could not determine the firmware state of the partner through the HA interconnect.
Sun Aug 17 21:58:31 GMT [N6220-SAS:tar.csum.match:info]: Stored checksum matches, not extracting /mroot_late.tgz.
Sun Aug 17 21:58:31 GMT [N6220-SAS:tar.csum.match:info]: Stored checksum matches, not extracting /platform/pmroot_late.tgz.
Sun Aug 17 21:58:32 GMT [N6220-SAS:sp.notConfigured:warning]: The system's Service Processor (SP) is not configured. Use the 'sp setup' command to configure it.
Sun Aug 17 21:58:32 GMT [N6220-SAS:sp.network.link.down:warning]: Service Processor (SP) network port link down due to cable or network errors.
Sun Aug 17 21:58:32 GMT [N6220-SAS:cf.hwassist.DefaultPrtnrPort:notice]: The system has chose the default hardware-assist partner port number 4444. If you want to use a different port number, change it using the command 'options cf.hw_assist.partner.port'.
Sun Aug 17 21:58:32 GMT [N6220-SAS:cf.hwassist.DefaultEnabled:info]: Hardware-assisted takeover feature is enabled on this system. The partner can take over this node faster during certain failures.
Sun Aug 17 21:58:32 GMT [N6220-SAS:cf.hwassist.Default.NodemgmtAddr:notice]: The system automatically chose 192.168.1.139 as the local hardware-assist IP address.
Sun Aug 17 21:58:36 GMT [N6220-SAS:nbt.nbns.socketError:error]: NBT: Cannot send broadcast message on NBNS socket. Error 0x32: Network is down.
Sun Aug 17 21:58:49 GMT [N6220-SAS:nbt.nbns.registrationComplete:info]: NBT: All CIFS name registrations have completed for the local server.
Sun Aug 17 21:59:00 GMT [N6220-SAS:monitor.globalStatus.critical:CRITICAL]: Controller failover partner unknown. Controller failover not possible.
Sun Aug 17 21:59:10 GMT [console_login_mgr:info]: root logged in from console
Sun Aug 17 21:59:26 GMT [N6220-SAS:callhome.performance.snap:info]: Call home for PERFORMANCE SNAPSHOT
Sun Aug 17 22:00:00 GMT [N6220-SAS:kern.uptime.filer:info]:  10:00pm up 2 mins, 0 NFS ops, 0 CIFS ops, 0 HTTP ops, 0 FCP ops, 0 iSCSI ops
Sun Aug 17 22:00:04 GMT [N6220-SAS:sp.network.link.down:warning]: Service Processor (SP) network port link down due to cable or network errors.
Sun Aug 17 22:00:04 GMT [N6220-SAS:cf.takeover.disabled:warning]: Controller Failover is licensed but takeover of partner is disabled.
Sun Aug 17 22:00:04 GMT [N6220-SAS:cf.ic.hourlyBackplaneLinkDownTime:error]: Backplane Interconnect link has been down for 2 minutes
Sun Aug 17 22:00:35 GMT [N6220-SAS:cf.misc.operatorEnable:notice]: Failover monitor: operator initiated enabling of failover.
Sun Aug 17 22:00:35 GMT [N6220-SAS:cf.fsm.takeoverOfPartnerDisabled:notice]: Failover monitor: takeover of partner disabled (partner mailbox disks not accessible or invalid).
Sun Aug 17 22:00:35 GMT [N6220-SAS:cf.fsm.takeoverByPartnerDisabled:notice]: Failover monitor: takeover of N6220-SAS by partner disabled (interconnect error).
Sun Aug 17 22:00:39 GMT [N6220-SAS:cf.fsm.partnerNotResponding:notice]: Failover monitor: partner not responding
Sun Aug 17 22:00:49 GMT [N6220-SAS:ha.takeoverImpDegraded:warning]: Takeover of the partner node is impossible due to lack of connectivity to the partner mailbox disks.
Sun Aug 17 22:01:04 GMT [N6220-SAS:netif.linkUp:info]: Ethernet e0a: Link up.
Sun Aug 17 22:03:11 GMT [N6220-SAS:wafl.quota.sec.change:notice]: security style for /vol/vol0/ changed from unix to mixed
Sun Aug 17 22:04:00 GMT [N6220-SAS:wafl.quota.sec.change:notice]: security style for /vol/vol0/ changed from mixed to ntfs
Sun Aug 17 22:06:20 GMT [N6220-SAS:netif.linkDown:info]: Ethernet e0a: Link down, check cable.
Sun Aug 17 22:06:24 GMT [N6220-SAS:netif.linkUp:info]: Ethernet e0a: Link up.
Sun Aug 17 22:08:51 GMT [telnet_0:info]: root logged in from host: 192.168.0.100
Sun Aug 17 22:09:30 GMT [N6220-SAS:netif.linkDown:info]: Ethernet e0a: Link down, check cable.
Sun Aug 17 22:09:43 GMT [N6220-SAS:netif.linkUp:info]: Ethernet e0a: Link up.
Sun Aug 17 22:09:50 GMT [telnet_0:info]: root logged in from host: 192.168.0.100
Sun Aug 17 22:10:48 GMT [N6220-SAS:callhome.partner.down:CRITICAL]: Call home for PARTNER DOWN, TAKEOVER IMPOSSIBLE
Sun Aug 17 22:11:16 GMT [N6220-SAS:netif.linkDown:info]: Ethernet e0a: Link down, check cable.
Sun Aug 17 22:25:08 GMT [N6220-SAS:netif.linkUp:info]: Ethernet e0a: Link up.
Sun Aug 17 22:25:24 GMT [telnet_0:info]: root logged in from host: 192.168.0.100
N6220-SAS*>
DOMINIC_WYSS
I think you have a physical connection issue on the ports, they are not coming up.
which cables are you using?
aborzenkov
DOMINIC_WYSS
good idea about the ha-config!
but it has to be set to ha, even if it's a single-chassis.
https://library.netapp.com/ecmdocs/ECMM1249823/html/haconfig/GUID-F4091101-4D6B-4577-B337-CBA633143BAC.html
maybe one of the chassis is set to non-ha and does not respond to the interconnect requests?
shane_bradley
ah of course !
didnt even think about that
