ONTAP Hardware
FC configuration on FAS2552
nazandrey
Hello!
We have a demo equipment Netapp FAS2552 (Clustered ONTAP) and the Cisco UCS C22 server with FC adapter,
I want to try to configure the "SAN boot" directly connecting the server to the storage system by FC.
Please tell me that need for this?
1 REPLY 1
Sahana
Hi,
Direct-attached FC configurations are not supported with multiple node clusters.Refer page 20 in https://library.netapp.com/ecm/ecm_download_file/ECMP1636036
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
