ONTAP Hardware
FCoE Configuration
meanjeans
Hello,
I would like to know if there is a document  that describes the process for configuring/troubleshooting the FCoE 10G  interfaces for a NetApp.  I am painfully new to NetApp so I apologize  for asking what is likely a dumb question.
Huge Thanks!
- Josh
1 ACCEPTED SOLUTION
radek_kubka
Hi Josh & welcome to the Communities!
Have you read this document?
Fibre Channel over Ethernet (FCoE) End-to-End Deployment Guide
http://www.netapp.com/us/library/technical-reports/tr-3800.html
Re troubleshooting (rather vague though!):
http://now.netapp.com/NOW/knowledge/docs/hba/win/relwinhu52/html/software/rnote/GUID-A0947F0F-99C6-43F1-92BB-1B144ADA6513.html
Regards,
Radek
2 REPLIES 2
radek_kubka
Regards,
Radek
meanjeans
That is what I am looking for.  Thanks!
