ONTAP Hardware
Fabric Metrocluster cDOT cabling schema?
gmilazzoitag
Hi,
where I can find cabling schema e/o designs about available FMC MetroCluster in cDOT 8.3? Two nodes and four nodes?
The TR3548 used for 7Mode was full of very good designs depicting the real deployment of cable to and from controller and switched.
The TR4375 for cDOT instead contains only logical schema.
Regards,
1 REPLY 1
Sahana
Hi
Please refer Fabric-attached MetroCluster™ Installation and Configuration Guide
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
