ONTAP Hardware
Failing PSUs in FAS2040
ETB
Hi all,
We have moved hardware from our Netherlands to Scotland site.  All equipment was working in NL and was powered down correctly and professionally transported.
Included in the move are 6x FAS2040.  So far all PSUs from 3 have blown on power up.
Any ideas?
Power Supplys fitted are CP-1103R2
2 REPLIES 2
hariprak
Hi,
Ensure that there is adequate power to the storage shelves. Refer to the Disk Shelf Installation and Service Guide for Power Supply requirements.
You can also refer to the below link which talks about Power supply issues.
https://kb.netapp.com/support/index?page=content&id=3013824#Anchor1
Thanks
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
hariprak
Hi,
Thanks
