ONTAP Hardware
FcOE IBM N 6040 (FAS3140)
nsitps1976
Has anyone any experience of using native FCoE with this system - We are exploring a green field solution using end-to-end FCoE, see below:
IBM x3850 X5
Qlogic CNAs
VMware vSphere
Cisco Nexus 5010
IBM N 6040
Has anyone done this, tested this? - What was your experience, should we consider it or should we look at FC at the array with FCoE from the switch to the ESX servers?
1 REPLY 1
nsitps1976
One other thing, I has read somewhere that you need to use the Nexus 1000v on your ESX servers to support FCoE over CNAs - Is this correct?
