ONTAP Hardware
Flash Cache System Read Latency
justinfibe
Dears
Is the system read latency value of 619ms in the yellow line part normal!?
How is this value calculated?
1 ACCEPTED SOLUTION
ttran
Hello Justinfibe,
No, that is not normal. Was there anything else going on with the system during the observed time of high latency, like a storage failover/giveback where the FlashCache has to re-warm its contents? If nothing else was going on then I suggest you open a case with our Support Team to rule out any failing hardware, i.e. failing FlashCache, failing disks, failing shelf modules, etc...
Regards,
Team NetApp
Team NetApp
1 REPLY 1
ttran
Hello Justinfibe,
Regards,
Team NetApp
Team NetApp
