ONTAP Hardware
Flash Cache appears as failed and is on Firmware Version NA03 or later
TyrannosaurusWEST
Is anyone familiar with this particular error?
Also is there a way to correct the issue with a Syntx or soft command or is a hardware replacement required.
  • Flash Cache NVMe Offline message received
FLNVME:HA Group Notification from FAS2750-Node02 (Flash Cache NVMe Offline) ALERT
  • Flash Cache appears as failed and is on Firmware Version NA03 or later
slot 1: Flash Cache NVMe
Serial Number:      ZEP008W9
Part Number:        119-00329
Hardware Revision:  A0
Firmware Version:   NA03
Model Name:         X3311A
Capacity:           1024 GB
State:              failed
1 REPLY 1
pedro_rocha
Hello my friend...
As you probably saw on the KB article.. this needs to be replaced...
Regards,
Pedro
