ONTAP Hardware
Head Swap from FAS8300 to FAS8700
lucabisceglia
Hi, we have to head swap from FAS8300 to FAS8700. In the documentation I can't find anything but I'm pretty sure that this is due the fact that FAS8300 and FAS8700 are basically the same storage with the processor and memory difference.
Do you have access to some documentation stating this point ?
Many thanks Luca
1 ACCEPTED SOLUTION
andris
I haven't seen this particular question, before.  Non-disruptive in-chassis HW upgrade is not supported - it would get hung up on seeing mixed controllers in the chassis, IMO.
Thinking about it, it would have to be disruptive and you'd need to move any data off the FAS8300, first.
  1. Evacuate data off attached storage
  2. Unjoin FAS8300 (if applicable)
  3. Use parts of the "repurpose KB" workflow to init the FAS8300 and the attached storage (MSID 0x0 for encrypting drives, wipeclean, option 9a, etc.)
  4. Swap out the FAS8300 with FAS8700 controllers and recable
  5. Boot and init the FAS8700, create or join the cluster
  6. Move your data back.
3 REPLIES 3
andris
Are you talking about a controller upgrade to a complete FAS8700 in its own separate chassis, or are you asking about in-chassis controller upgrades?
Top-level doc topic: https://docs.netapp.com/us-en/ontap-systems-upgrade/index.html
lucabisceglia
In chassis controller upgrade
Thanks
andris
