ONTAP Hardware
Help: Understanding Volume available space
timbauerna
Hey guys,
I have a question about available space on NetApp FAS system.
Here the givens:
Volume - 400GB / Flexible / 10% Snapshot reserve
One LUN in this Volume - 150,0021GB / Space Reserved
So my calculation is:
400GB - 150GB - 150GB (first Snapshot) - 40GB = 60GB available
two questions:
-there is more than one snapshot available... how is it possible, that my volume available storage shows: 77,5GB?
-Snapshots are stored in normal data space... when data space is full, they will use the snapshot reserve... right?
thanks for your help
regards!
12 REPLIES 12
sriegerdss
Data will never live in snapshot space
Snapshots however can live in data space
timbauerna
OK, thanks for your fast response.
that means, that I'm right, saying, that for snapshots the data space is used and when data space is full snapshots will use their reserved space?
regards
sriegerdss
If you set snapreserve then snapshots will live there. Once your snapshots
take up all the reserve, they either rotate off or fail, depending on your
setup
aborzenkov
Sorry, but that’s completely wrong. Snap reserve never limited how much space snapshots can consume.
You can set policy to delete snapshots if snapreseve gets full (which is not default) but it will never cause snapshots to fail.
sriegerdss
You're correct.
However if the data side is full and your snap reserve is full then it
might happen.
timbauerna
Thats my thoughts to... I need to know... Is my calculation right? (see first post)
it's based on the thoughts, that snapshots use the dataspace and when it's full they will use the snapshot reserved space... can you please take a look on my calculation?
thanks
regards
ekashpureff
Err, not exactly.
Snap reserve space will show used for changed blocks as data in the LUN is overwritten after taking a snapshot.
Fractional reserve is another mechanism for reserving space in a volume for overwriting blocks in a LUN which has had a snapshot taken.
Snap reserve is usualy set to zero for volumes containing a LUN, given that we have Fractional reserve to use to guarantee overwrites.
See the 'Storage Provisioning' section of the 'Block Access Management Guide'.
There's also an excellent TR on thin provisioning in a SAN environment:
http://media.netapp.com/documents/tr-3483.pdf
You may also wish to look at tr3563.
I hope this response has been helpful to you.
At your service,
Eugene E. Kashpureff
[email protected]
Fastlane NetApp Instructor and Independent Consultant
http://www.fastlaneus.com/ http://www.linkedin.com/in/eugenekashpureff
(P.S. I appreciate points for helpful or correct answers.)
timbauerna
OK, thanks... I got this...
but  is my calculation in the first post right? How is it possible to have  more free space than calculated... with more than one snapshot??? (I  calculated with one snapshot)
Please take a look at it...
Thanks!
regards
ekashpureff
Your calculation in the first post is close, but the LUN wasn't full of data.
The LUN cost you  150G, but the first snap only took ~133G more, 'cause you
only had that much data written to the LUN. Additional snapshots would only
take up the delta ammount of space.
With fractional reserve at 100% ONTAP guaranteed space to write 150G more.
At your service,
[email protected]
timbauerna
Oh of course... the LUN File has a size of 150GB, but the NetApp filer knows wich blocks are written.. so the snapshot will only take the written blocks...
I should take the exactly LUN size for my calculation...
thanks!
joostvandrenth
I actually like SAN volumes to be thin and hold a snap reserve to monitor the level of snap capacity usage against: the thin provisioned vol will always leave some additonal capacity while having a snap reserve will allow a level of automation to curtain unwanted snap growth.
just my 2 cents.
ekashpureff
Joost -
That thin provisioning will work out to a lot more than two cents worth of storage !
This could be a very valuable comment to any who are not thin provisioning...
At your service,
[email protected]
