ONTAP Hardware
Hot Adding 3 FC shelves when to power on?
raef_mansour
Hello
I will hot add 3 fc shelves to existing configuration.
For cabling between shelves it's ok for cabling with both head it's ok.
I need to configure fc port to initiator and  do a takeover.
when should I power on the 3 shelves? after finishing the config of fc port on both filer?
Or should I power them on and then connect the 4 fc cable to both head ( HA cabling)/
4 REPLIES 4
pmeidell
This procedure is documented in Appendix A of the ds14 hardware manual. It is very explicit, including when to power on the shelf.
https://library.netapp.com/ecm/ecm_download_file/ECMP1112854
raef_mansour
thanks but is it the same if I add multiple shelf at the same time?
pmeidell
I hate to be an old fuddy duddy about this, but the Appendix I referenced above starts by saying:
NetApp recommends that you hot-add one disk shelf at a time.
If you want to add all three at once, you'll be violating the recommended approach. You can proceed, and it will probably work just fine if you do it correctly. But since adding multiple shelves simultaneously isn't recommended, there is no documented "correct" method.
The main thing is to ensure that the three shelves have unique shelf IDs. Shelf ID uniqueness must be maintained among all shelves that will be connected to the loop in the final configuration. Be sure to set the shelf ID with the selector switches BEFORE you power up the shelves. Interconnect your 3 shelves as you normally would, then connect the first shelf to your loop in accordance with the instructions for connecting a single shelf. Just use common sense, and I'm confident you'll be fine.
Good luck.
pmeidell
By the way, the process for adding a disk shelf assumes you will be attaching the shelf to an initiator port, so complete the fc port reconfiguration before starting with your shelves.
