ONTAP Hardware
How can I convert from Dual Node to Single cluster node
NghiaTD
Dear all community!
 I'm a newbie. I have some new Netapp FAS2620 try to convert from Dual Node configure to Single cluster node. But I don't know how to convert, anyone can help me procedure to convert?
Thanks!
5 REPLIES 5
SpindleNinja
So you have an HA pair and want to take it down to a single node?    Why?
But you'd have to rebuilt it as a single controller cluster.  You can't just remove one node from the pair.
NghiaTD
Hi SpindleNinja!
Sorry for reply late. For some sensitive reason, I want to rebuild again device with single node. And what I have to do now?
 Please instruct to me detail because I don't know what i have to do first.
Now I just only have a controller, another controller already move to another site. What I have to do for both?
Or I just need access to boot menu and choose option: (4) Clear configuration and initialize all disks?
Thanks for reply and hope you will help me.
SeanHatfield
This should get you most of the way there:
https://library.netapp.com/ecmdocs/ECMP1367947/html/GUID-28F4D4C7-AB46-4FA7-8C51-66CC9DC4E5EE.html
I think there's an extra step on the shared chassis boxes to set the chassis mode.  This should cover it:
https://library.netapp.com/ecmdocs/ECMP1367947/html/GUID-14AF35BF-BC87-4226-801D-ED0CF3FA0B0F.html
If you've whacked your aggrs when you tore it apart you'll also need to re-init.  boot menu option 9 to nuke the partitions, set-defaults in the loader, then back to the boot menu and option 4.  You could have some disk ownership by the node thats MIA to sort out too.  Should be fun, but you might need professional help if you aren't skilled in the art.
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
NghiaTD
Hi SeanHatfield!
I've rebuild single cluster success, but I'm not sure all about my configuration is right!
Can you check for me follow information bellow:
netapp::> disk show
                     Usable           Disk    Container   Container
Disk                   Size Shelf Bay Type    Type        Name      Owner
Info: This cluster has partitioned disks. To get a complete list of spare disk
      capacity use "storage aggregate show-spare-disks".
1.1.0                5.35TB     1   0 FSAS    shared      aggr0     netapp-01
1.1.1                5.35TB     1   1 FSAS    shared      aggr0     netapp-01
1.1.2                5.35TB     1   2 FSAS    shared      aggr0     netapp-01
1.1.3                5.35TB     1   3 FSAS    shared      aggr0     netapp-01
1.1.4                5.35TB     1   4 FSAS    shared      aggr0     netapp-01
1.1.5                5.35TB     1   5 FSAS    shared      aggr0     netapp-01
1.1.6                5.35TB     1   6 FSAS    shared      aggr0     netapp-01
1.1.7                5.35TB     1   7 FSAS    shared      aggr0     netapp-01
1.1.8                5.35TB     1   8 FSAS    shared      aggr0     netapp-01
1.1.9                5.35TB     1   9 FSAS    shared      aggr0     netapp-01
1.1.10               5.35TB     1  10 FSAS    shared      aggr0     netapp-01
1.1.11               5.35TB     1  11 FSAS    shared      aggr0     netapp-01
netapp::> system node run * sysconfig -r
1 entry was acted on.
Node: netapp-01
Aggregate aggr0 (online, raid_dp) (block checksums)
  Plex /aggr0/plex0 (online, normal, active, pool0)
    RAID group /aggr0/plex0/rg0 (normal, block checksums)
      RAID Disk Device          HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)    Phys (MB/blks)
      dparity   0b.01.1P2       0b    1   1   SA:A   0  FSAS  7200 147102/301265408  147110/301281792
      parity    0b.01.3P2       0b    1   3   SA:A   0  FSAS  7200 147102/301265408  147110/301281792
      data      0b.01.5P2       0b    1   5   SA:A   0  FSAS  7200 147102/301265408  147110/301281792
      data      0b.01.7P2       0b    1   7   SA:A   0  FSAS  7200 147102/301265408  147110/301281792
      data      0b.01.9P2       0b    1   9   SA:A   0  FSAS  7200 147102/301265408  147110/301281792
      data      0b.01.4P2       0b    1   4   SA:A   0  FSAS  7200 147102/301265408  147110/301281792
      data      0b.01.6P2       0b    1   6   SA:A   0  FSAS  7200 147102/301265408  147110/301281792
      data      0b.01.8P2       0b    1   8   SA:A   0  FSAS  7200 147102/301265408  147110/301281792
      data      0b.01.10P2      0b    1   10  SA:A   0  FSAS  7200 147102/301265408  147110/301281792
      data      0b.01.11P2      0b    1   11  SA:A   0  FSAS  7200 147102/301265408  147110/301281792
      data      0b.01.0P2       0b    1   0   SA:A   0  FSAS  7200 147102/301265408  147110/301281792
      data      0b.01.2P2       0b    1   2   SA:A   0  FSAS  7200 147102/301265408  147110/301281792
Pool1 spare disks (empty)
Pool0 spare disks
Spare disks for block checksum
spare           0b.01.0P1       0b    1   0   SA:A   0  FSAS  7200 5467482/11197403648 5467490/11197420032
spare           0b.01.1P1       0b    1   1   SA:A   0  FSAS  7200 5467482/11197403648 5467490/11197420032
spare           0b.01.2P1       0b    1   2   SA:A   0  FSAS  7200 5467482/11197403648 5467490/11197420032
spare           0b.01.3P1       0b    1   3   SA:A   0  FSAS  7200 5467482/11197403648 5467490/11197420032
spare           0b.01.4P1       0b    1   4   SA:A   0  FSAS  7200 5467482/11197403648 5467490/11197420032
spare           0b.01.5P1       0b    1   5   SA:A   0  FSAS  7200 5467482/11197403648 5467490/11197420032
spare           0b.01.6P1       0b    1   6   SA:A   0  FSAS  7200 5467482/11197403648 5467490/11197420032
spare           0b.01.7P1       0b    1   7   SA:A   0  FSAS  7200 5467482/11197403648 5467490/11197420032
spare           0b.01.8P1       0b    1   8   SA:A   0  FSAS  7200 5467482/11197403648 5467490/11197420032
spare           0b.01.9P1       0b    1   9   SA:A   0  FSAS  7200 5467482/11197403648 5467490/11197420032
spare           0b.01.10P1      0b    1   10  SA:A   0  FSAS  7200 5467482/11197403648 5467490/11197420032
spare           0b.01.11P1      0b    1   11  SA:A   0  FSAS  7200 5467482/11197403648 5467490/11197420032
netapp::> storage aggregate show-spare-disks
Original Owner: netapp-01
 Pool0
  Root-Data Partitioned Spares
                                                              Local    Local
                                                               Data     Root Physical
 Disk             Type   Class          RPM Checksum         Usable   Usable     Size Status
 1.1.0            FSAS   capacity      7200 block            5.21TB       0B   5.37TB zeroed
 1.1.1            FSAS   capacity      7200 block            5.21TB       0B   5.37TB zeroed
 1.1.2            FSAS   capacity      7200 block            5.21TB       0B   5.37TB zeroed
 1.1.3            FSAS   capacity      7200 block            5.21TB       0B   5.37TB zeroed
 1.1.4            FSAS   capacity      7200 block            5.21TB       0B   5.37TB zeroed
 1.1.5            FSAS   capacity      7200 block            5.21TB       0B   5.37TB zeroed
 1.1.6            FSAS   capacity      7200 block            5.21TB       0B   5.37TB zeroed
 1.1.7            FSAS   capacity      7200 block            5.21TB       0B   5.37TB zeroed
 1.1.8            FSAS   capacity      7200 block            5.21TB       0B   5.37TB zeroed
 1.1.9            FSAS   capacity      7200 block            5.21TB       0B   5.37TB zeroed
 1.1.10           FSAS   capacity      7200 block            5.21TB       0B   5.37TB zeroed
 1.1.11           FSAS   capacity      7200 block            5.21TB       0B   5.37TB zeroed
12 entries were displayed.
SeanHatfield
Looks like you need to make a data aggregate.
