ONTAP Hardware
How to Update CN1610 Cluster Switch
JustinM
Hi all,
I have been tasked with updating the firmware on the following sets of switches:
  • 2* NetApp CN1610 Cluster Switches
  • 2* NetApp CN1601 Management Switches
  • 2* HP StorageWorks 8/40 Power Pack+ FC SAN Switches
  • 2* HP SN600B FC SAN Switches
  • 4* HP Brocade 8Gb Blade FC SAN Switches
I am looking for some advice on how to achieve this including what I need to look out for etc.
I look forward to your responses.
Regards
2 REPLIES 2
robinpeter
Its lil more than a week..I'm sorry that nobody replied to your post..
if you are still looking for it.. here is what I have.
CN1610 Cluster Switch : Installing FASTPATH software and RCFs on a NetApp cluster switch
CN1601 Management Switch : Installing FASTPATH software and RCFs on a NetApp Mgmt switch
For rest of the hardware you might have to find from the respective hardware vendor...
thanks,
Robin.
saranraj456
Whether the steps provided in this link -Installing FASTPATH software and RCFs on a NetApp cluster switch for CN 1610 Switch upgrade is only applicable for version 1.2.0.7  or is it applicable for all other down the line versions ? , because the steps like Lif migration and ISL disable was skipped in this following link -https://mysupport.netapp.com/NOW/download/software/sanswitch/fcp/NetApp/cn1610cm/download.shtml#1.2.0.7 for version below 1.2.0.7 . Someone please clarify ?
Thanks
Saran
