ONTAP Hardware
How to check if LACP configured correctly
NAYABRASOOL
Hi Experts,
Recently we have a problem of High Disk usage on one of our filer and when we tried to troubleshoot i came to know one particular ethernet card e0a was having huge reads and writes going in and out and other having less i.e., e0b now the question is this is something to deal about switch LACP i suspect this is something with the switch. Could you people please help me to troubleshoot this and get this fixed Please.
Thanks,
Nayab
1 ACCEPTED SOLUTION
nigelg1965
Hi
The command ifstat interface should help, interface can be the physical port e0a e1b etc or the vif name.
Check are you using LACP as the trunk method on the VIF and of course the switch config.
1 REPLY 1
nigelg1965
Hi
