ONTAP Hardware
How to check my netapp storage Serial Number
HENRY_WANG
I want to know my netapp storage serial number , I connect this device via it's management IP , then I login the web page ,but can't find where's the SN.
I'm on a local office ,and my device is in my IDC room ,so I only use the web manage it .
1 ACCEPTED SOLUTION
Drew_C
We've come a long way since this question was asked, and the responses offered aren't necessarily the most accurate anymore. For those who arrive here via search, the best solution can be found in our knowledge base.
How to Identify the Serial Number for my ONTAP Platform?
Community Manager \\ NetApp
5 REPLIES 5
CHANDRAREDDY
Hi,
can you putty to the filer?
use sysconfig -a command to get the info about controllers, which includes serial number as well.
HENRY_WANG
thanks for your respon。
发自我的 iPhone
在 2014年7月24日,21:08,CHANDRAREDDY <[email protected]> 写道:
Re: How to check my netapp storage Serial Number
created by CHANDRAREDDY in FAS and V-Series Storage Systems - View the full discussion
Hi,
Reply to this message by replying to this email -or- go to the message on NetApp Community
Start a new discussion in FAS and V-Series Storage Systems by email or at NetApp Community
JOHNBHOLA
Hi,
User sysconfig -a command
the third line of this command out put is system serial number.
Regards,
Bhola Gond
HENRY_WANG
thanks
发自我的 iPhone
在 2014年7月24日,21:24,JOHNBHOLA <[email protected]> 写道:
created by JOHNBHOLA in FAS and V-Series Storage Systems - View the full discussion
Hi,
Regards,
Bhola Gond
Drew_C
