ONTAP Hardware
How to get a printout of the Configuration and volumes
STANCENLISI
Hello All: I am new at my company and  have been put in charge of the NetApp FAS 2220 with a partially filled extra shelf.
Before I have to start reconfiguring this, how do I get a complete report of the current configuration and settings?.
Thank you,
1 REPLY 1
JGPSHNTAP
Sounds like you might be a little new to netapp as well..   You can use system manager, oncommand to get a listing of your system, or if you know powershell, you can browse over the powershell forum, i've written some scripts that will do what you need, as others have as well
