ONTAP Hardware
How to use multiple vscan servers
jenoptik
Hi,
I'm trying to use two primary vscan server for our netapp filer but I can only use one primary and one secondary.
As can be seen in the manual it is possible to use multiple primary vscan server.
How can I do this in  Data Ontap 8.2.2 (FAS8020) ?
Thx for your help.
4 REPLIES 4
richard_payne
Yes it's possible to have multiple primary vscan servers. Just configure the vscan servers with the filer information and allow them to connect. I've never needed to add them on the file server side. I know we looked at the 'secondaries' feature a while back but deterimed it didn't give us any advantage and instead just allow them all to connect to the filers themsevles.
--rdp
hariprak
Hi,
Yes, it's possible to have two primary vscan servers.  Two primary vscan servers creates a round-robin where both servers split the scanning load.
For more details, refer the KB article https://kb.netapp.com/support/index?id=3013679&page=content&locale=en_US
Thanks
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
jenoptik
I cannot open your link, i got an unexpected error message.
Can you check the link again?
Renifa
Hi Jenoptik
It is possible to have two primary vscan server. Following is the link from netapp KB site which explains the same process.
https://kb.netapp.com/support/index?page=content&id=3012425&actp=search&viewlocale=en_US&searchid=1444120524337
Thanks.
