ONTAP Hardware
IBM NSeries monitoring
VIVISIMOIT
Is anyone using the IBM branded 2240 aka nseries N3240 and IBM's support?  I am curious if IBM offers a dashboard like Fitness Advisor and Upgrade Advisor?  It only looks like i can link my "real" netapps to it and not my nseries.
1 ACCEPTED SOLUTION
andris
Hi,
For IBM N-Series systems, those tools are only available to IBM Technical Support. I would contact them if you require an Upgrade Advisor plan.
1 REPLY 1
andris
Hi,
