ONTAP Hardware
Implementation plan for NetApp FAS storage FAS 2750
victorlagat
NetApp FAS storage FAS 2750 (24x8TB)
Storage Unit for Backup & Archiving for PDC and DR
2 REPLIES 2
aladd
the NSS contains a setup guide for the 2750, as well as configuration for DR setups depending on the vertsion of ONTAP you are configuring.
If you would like a personalized plan drawn up, NetApp offers services for this.
https://docs.netapp.com/platstor/topic/com.netapp.nav.fas2700/home.html?cp=7
https://docs.netapp.com/ontap-9/topic/com.netapp.nav.dpdr/home.html?cp=7
pedro_rocha
Do you have any idea or specific doubt so we can elaborate more on your needs?
Your system is kind of simple, you don't have much to play. Which drives are that (part number)?
ADP so your root aggregates does not steal too much space and your data aggregates use the most of the drives.
