ONTAP Hardware
Info SNMP
LUIGI_TAMAGNONE
 Hi,
I try to configure SNMP on Netapp to monitoring netapp network port with cacti.
First i tried with NetApp FAS8020 Release 8.2.2 Cluster-Mode and works fine, after i tried with NetApp FAS3220 Release 8.2P5 Cluster-Mode but not work.
If i try with SNMP walk i receive this two answer:
snmpwalk -v 2c -m NETAPP-MIB -c public IP_FAS8020 1.3.6.1.4.1.789.1.22.1.2.1.2
NETAPP-MIB::netifDescr.1 = STRING: NAME_FAS8020-01:e0d
NETAPP-MIB::netifDescr.2 = STRING: NAME_FAS8020-01:e0c
snmpwalk -v 2c -m NETAPP-MIB -c public IP_FAS3220 1.3.6.1.4.1.789.1.22.1.2.1.2
NETAPP-MIB::netifDescr = No Such Object available on this agent at this OID
Someone know why FAS3220 not find network object? There is something to configure?
Thanks.
Luigi
2 REPLIES 2
YIshikawa
MIB definition is different between Data.ONTAP version. Please check MIB for Data ONTAP 8.2 if correspondent OID exist.
# I can not open .Z file now on my iPad, so I can't confirm.
http://mysupport.netapp.com/NOW/download/tools/mib/
LUIGI_TAMAGNONE
For 8.2 and 8.2.2 version when i serch ifHighInOctets or if64InOctets, the OID is the same (.1.3.6.1.4.1.789.1.22.1.2.1.3 or .1.3.6.1.4.1.789.1.22.1.2.1.25)
