ONTAP Hardware
Interpretation of cpuCount mib
Jarek
FAS 6280 system can host two 6 core 12 threads X5670
Given snmpget returns cpuCount=12 for
iso.3.6.1.4.1.789.1.2.1.6.0 = INTEGER: 12
Would the 12 be the number of cores, or threads?
Does it mean there are 1 or 2 sockets fitted?
4 REPLIES 4
paul_stejskal
That doesn't sound right. If you run a sysstat -M from the node shell or 7-mode (requires diag), it should show 8 CPU cores IIRC on the 6280. The 6290 has 12 cores.
paul_stejskal
I stand corrected. Maybe I'm thinking 6250. It's been a few years since I've seen those systems.
Looking at HWU:
https://hwu.netapp.com/Controller/Index?platformTypeId=2032
Processor Model
Processor Architechture
Processor Speed
Processor Count (Per Node)
64-bit 6-core 2.93 GhzFAS6280 - Dual Chassis HA Pair with IO Expansion
ONTAP 9.1
Processor Model
64 bit
2.93 Ghz
2
Jarek
Thanks for the reply,
FAS6280 can have two x5670.
Each has 6 cores, and thus as per below page 12 threads,
https://ark.intel.com/content/www/pl/pl/ark/products/47920/intel-xeon-processor-x5670-12m-cache-2-93-ghz-6-40-gt-s-intel-qpi.html
Would those 12, be threads of single CPU, or cores of two CPUs?
IOW.  Having second socket fitted, should there to be 24?
paul_stejskal
sysstat -m would show you from CLI/node shell. I think the highest I've seen is 12 cores. It doesn't count hyperthreaded cores as separate but shows physical.
