ONTAP Hardware
Is there any document comparing FAS31XX to FAS 32X0 ?
yanivyaakov
Hi All,
I'm Looking for a Document that i could comapre the two versions of systems so when i talk to customers i could have the right tools to explain the exact differences between the systems and the roadmap,
can you post a link for these documents ?
Yaniv
4 REPLIES 4
ekashpureff
3100 Data Sheet - http://media.netapp.com/documents/netapp-fas3100-series-datasheet.pdf
3200 Data Sheet - http://media.netapp.com/documents/ds-3095.pdf
I hope this response has been helpful to you.
At your service,
Eugene Kashpureff
NetAppU Instructor and Independent Consultant
(P.S. I appreciate points for helpful or correct answers.)
peluso
Hi - you may want to look at the tech specs
3200 -- http://www.netapp.com/us/products/storage-systems/fas3200/fas3200-tech-specs.html
3100 -- http://www.netapp.com/us/products/storage-systems/fas3100/fas3100-tech-specs.html
And if you need anything more, let us know!
Terri
Thanks so much!
Terri Peluso
Senior Community Program Manager
jimmcclung
As we are considering a FAS3200 purchase next year, we would like to see something like what was compared in the recent Tech OnTap between the FAS6200 and FAS6080/FAS3100 systems.
http://communities.netapp.com/docs/DOC-8169
Why did that not compare the FAS3200 series as well? Or perhaps someone can make a FAS3200 vs. FAS3100/FAS6000 comparison?
sshapiro
Jim,
The Tech OnTap article intentionally focused only on the FAS/V6200 Series.  In the FAS/V3200 SE presentation on Field Portal you'll find performance comparisons between FAS/V3200 and FAS/V3100 systems.
Skip
