ONTAP Hardware
LACP interface status : lag_inactive
MACAKIGO1
Hello All,
We stuck with investigation of one issue related with LACP
One port is failing to receive successive LACP protocol packets and staying in lag_inactive status.
netapp controller is sending LACP packets but doesn't receiving them from the switch.
Same behavior we can see on network switch(PDUs sent are increasing , however received PDUs are staying in same value).
We tried to reset interface but it didn't help.
our environment
FAS: FAS6210
network card: 10 Gigabit Ethernet Controller IX1-SFP+
ontap version: 8.2.1 7-Mode
switch is running :
Cisco Nexus Operating System (NX-OS) Software 5.2(7)
here is output from "vif status"
attached lacp_log file
ifgrp: command "vif" is deprecated in favor of command "ifgrp"
default: transmit 'IP Load balancing', Ifgrp Type 'multi_mode', fail 'log'
nas0: 1 link, transmit 'IP Load balancing', Ifgrp Type 'lacp' fail 'default'
Ifgrp Status Up Addr_set
up:
e0c: state up, since 28Nov2014 15:15:56 (48+23:04:26)
mediatype: auto-10g_sr-fd-up
flags: enabled
active aggr, aggr port: e0c
input packets 3239494, input bytes 4206978780
input lacp packets 619824, output lacp packets 620745
output packets 14182685, output bytes 20061316275
up indications 6, broken indications 0
drops (if) 0, drops (link) 0
indication: up at 28Nov2014 15:15:56
consecutive 0, transitions 6
lag_inactive:
e0e: state lag_inactive, since 16Jan2015 10:19:57 (04:00:25)
flags: lacp enabled
input packets 0, input bytes 0
input lacp packets 351670, output lacp packets 8406748
output packets 0, output bytes 0
up indications 9, broken indications 6
ifstat  of affected interface
-- interface e0e (0 hours, 10 minutes, 7 seconds) --
RECEIVE
Frames/second: 0 | Bytes/second: 0 | Errors/minute: 0
Discards/minute: 11 | Total frames: 0 | Total bytes: 0
Total errors: 0 | Total discards: 117 | Multi/broadcast: 0
No buffers: 0 | Non-primary u/c: 0 | L2 terminate: 0
Tag drop: 0 | Vlan tag drop: 0 | Vlan untag drop: 0
Vlan forwards: 0 | Vlan broadcasts: 0 | Vlan unicasts: 0
CRC errors: 0 | Runt frames: 0 | Fragment: 0
Long frames: 0 | Jabber: 0 | Bus overruns: 117
Queue drop: 0 | Xon: 0 | Xoff: 0
Jumbo: 0
TRANSMIT
Discards/minute: 61 | Total frames: 0 | Total bytes: 0
Total errors: 0 | Total discards: 618 | Multi/broadcast: 0
Queue overflows: 618 | No buffers: 0 | Xon: 0
Xoff: 0 | Jumbo: 0 | TSO non-TCP drop: 0
Split hdr drop: 0 | Pktlen: 0 | Timeout: 0
Timeout1: 0
LINK_INFO
Current state: up | Up to downs: 7 | Speed: 10000m
Duplex: full | Flowcontrol: none
Thanks
1 ACCEPTED SOLUTION
MACAKIGO1
This issue has been resolved by takoover/giveback.
2 REPLIES 2
MACAKIGO1
RUDeBega
Having the LACP PDU issue which the article says is solved. The link for the solution appears not to work. What is the solution?
