ONTAP Hardware
LINK NOT CONNECTED
jmishal
Hello
I just finish  new AFF a220 setup which is attached to our Cisco MDS 9148 to and I can not get a link between the two.
I've configured both sides of FC and matched the speed. (8Gb) I must be missing something in between that I can't figure out.
This is the setting/config for one of the connections SAN side:
Note : There is just something strange that the Physical Protocol: ethernet !!
CTRA::system*> fcp adapter show -instance -node CTRA-01
  (network fcp adapter show)
                          Node: CTRA-01
                       Adapter: 0c
                          UUID:
                   Description: Fibre Channel Target Adapter 0c (QLogic CNA 8324 (8362), rev. 2, CNA_10G)
                 Maximum Speed: 10
         Administrative Status: up
            Operational Status: link not connected
               Extended Status: ADAPTER UP
             Host Port Address: 0
             Firmware Revision: 8.9.0
         Data Link Rate (Gbit): 0
            Fabric Established: false
                   Fabric Name: -
        Connection Established: loop
     Is Connection Established: false
                     Mediatype: ptp
              Configured Speed: auto
      Data Protocols Supported: fcp
                   LIF Capable: true
                     THA Index: 2
                        Handle: 2
                 Physical Slot: 0
                 Original WWNN: 50:0a:09:80:0e:07:68:07
                  Adapter WWNN: 50:0a:09:80:80:43:46:b8
                  Adapter WWPN: 50:0a:09:83:80:43:46:b8
                   Queue Depth: 4096
                   Switch Port: :
    Form Factor Of Transceiver: SFP
    Vendor Name Of Transceiver: FINISAR CORP.
    Part Number Of Transceiver: FTLF8528P3BCV-QL
       Revision Of Transceiver: A
  Serial Number Of Transceiver: NT230NA
FC Capabilities Of Transceiver: 2,4,8 (Gbit/sec)
FC Capabilities Of Transceiver: 2, 4, 8
     Vendor OUI Of Transceiver: 00:90:65
      Wavelength In Nanometers: 850
      Date Code Of Transceiver: 15:01:12
       Validity Of Transceiver: true
                Connector Used: LC
                 Encoding Used: 8B10B
      Is Internally Calibrated: true
        Received Optical Power: 0.0 (uWatts)
    Is Received Power In Range: false
 SFP Transmitted Optical Power: 0.0 (uWatts)
        Is Xmit Power In Range: false
                          Node: CTRA-01
                       Adapter: 0d
                          UUID:
                   Description: Fibre Channel Target Adapter 0d (QLogic CNA 8324 (8362), rev. 2, CNA_10G)
                 Maximum Speed: 10
                   Fabric Name: -
                     Mediatype: ptp
                   LIF Capable: true
                     THA Index: 3
                        Handle: 3
                 Physical Slot: 0
                 Original WWNN: 50:0a:09:81:0e:07:68:07
                  Adapter WWPN: 50:0a:09:84:80:43:46:b8
                   Queue Depth: 4096
                   Switch Port: :
  Serial Number Of Transceiver: NT21986
                Connector Used: LC
                          Node: CTRA-01
                       Adapter: 0e
                          UUID:
                   Description: Fibre Channel Target Adapter 0e (QLogic CNA 8324 (8362), rev. 2, CNA_10G)
                 Maximum Speed: 10
                   Fabric Name: -
                     Mediatype: ptp
                   LIF Capable: true
                     THA Index: 0
                        Handle: 0
                 Physical Slot: 0
                 Original WWNN: 50:0a:09:82:0e:07:68:07
                  Adapter WWPN: 50:0a:09:81:80:43:46:b8
                   Queue Depth: 4096
                   Switch Port: :
  Serial Number Of Transceiver: NSR2Q2T
      Date Code Of Transceiver: 14:12:26
                Connector Used: LC
                          Node: CTRA-01
                       Adapter: 0f
                          UUID:
                   Description: Fibre Channel Target Adapter 0f (QLogic CNA 8324 (8362), rev. 2, CNA_10G)
                 Maximum Speed: 10
                   Fabric Name: -
                     Mediatype: ptp
                   LIF Capable: true
                     THA Index: 1
                        Handle: 1
                 Physical Slot: 0
                 Original WWNN: 50:0a:09:83:0e:07:68:07
                  Adapter WWPN: 50:0a:09:82:80:43:46:b8
                   Queue Depth: 4096
                   Switch Port: :
  Serial Number Of Transceiver: NSR2G76
                Connector Used: LC
4 entries were displayed.
1 ACCEPTED SOLUTION
SpindleNinja
What’s the output of “ucadmin show”. You might have to change the port from CNA to FC
3 REPLIES 3
SpindleNinja
jmishal
This is the output of the command, and as shown by Current Mode is CNA
CTRA::> ucadmin show
                       Current  Current    Pending  Pending    Admin
Node          Adapter  Mode     Type       Mode     Type       Status
CTRA-01       0c       cna      target     -        -          online
CTRA-01       0d       cna      target     -        -          online
CTRA-01       0e       cna      target     -        -          online
CTRA-01       0f       cna      target     -        -          online
CTRB          0c       cna      target     -        -          online
CTRB          0d       cna      target     -        -          online
CTRB          0e       cna      target     -        -          online
CTRB          0f       cna      target     -        -          online
8 entries were displayed.
Thank you for the clarification ,, I changed the mode to the fc for all adapter i need it as shown
fcp adapter modify -node CTRA-01 -adapter 0c -status-admin down
modify -node CTR-01 -adapter 0c -m fc
also i do  the same for the node B
seems to me everything went well.
thanks
SpindleNinja
No problem.  Be sure to also do takeovers on each node to set the change.    And verify that each port is FC/target.
