ONTAP Hardware
LifGrp Subnet mask change?
FicmanS
      I have a few filers that need to have the subnet mask change from 255.255.240.0 to 255.255.254.0 due to a routing change.  I am sitting on 172.16.1.159, .160, .161 and .162 IP's
      If I modify my RC file "ifconfig Lifgrp1-1 `hostname`-Lifgrp1-1 netmask 255.255.240.0 mtusize 1500 partner Lifgrp1-1 nfo" with the updated subnet mask info it shouold work and be nondrisruptive?   With the updated mask I will still be in proper scope for the 172.16.0.x and 172.16.1.x networks, I think I should be good.   Can anybody confirm that?
     IP adress remains the same, just tighten the mask...   7 mode 8.2.4p6 Ontap
Any thoughts?
Should I post this some where else?
0 REPLIES 0
